  3. markNet Options resets every time I use the tool
  • Subscribers 152
  • Views 9566
RicardoGV1
RicardoGV1 over 3 years ago
Hi everyone,
Does anybody know how to prevent the marknet options to get to the default values every time I close the options GUI.
I want to keep my previous settings (changes).
And I constantly need to change some parameters, so I need those new changes to be saved.
(Desired)
(Default after closing)
I've tried with this env vars, but didn't work
R.Gómez
  • DanhPham
    DanhPham over 2 years ago in reply to Andrew Beckett +1
    Hi Andrew and Ricardo, I have the same issue. I know the reason is when we use markNetOptionsFile env to load a custom config, every time we call marknet function, cadence will re-load that file and…
  • skillEater
    skillEater over 2 years ago in reply to DanhPham +1
    Hi I also have the same issue. If there is any solution, Please let me know. This will be very helpful. Thanks, Ganesh Doddipatla.
    That's odd. It doesn't happen for me, and I'm not aware of any mechanism to make it automatically reset every time. Which IC sub-version are you using?
  • RicardoGV1
    RicardoGV1 over 3 years ago in reply to Andrew Beckett
    Thanks for the response Andrew,
    My version is  IC6.1.8-64b.500.31
    Maybe should I need to upload a ticket?
  • DanhPham
    I have the same issue. I know the reason is when we use markNetOptionsFile env to load a custom config, every time we call marknet function, cadence will re-load that file and that loading will reset everything to what you write inside that file.
    Hi @Andrew, do you know any option to disable that step? I just want to load one when we open the Cadence.
  • skillEater
    Hi
    Ganesh Doddipatla.
