  3. Using special Keyboard keys as Bindkeys
  • Views 8318
Arokia
Arokia over 3 years ago
Hi All,
I've tried using the below special Keyboard keys as Bindkeys, but the same is not working, kindly assist
hiSetBindKey("Layout" "<Key>\" "leSetAllLayerVisible(nil) leSetLayerVisible(list(\"CO\" \"drawing\") t) hiRedraw()")
hiSetBindKey("Layout" "<Key>`" "leSetAllLayerVisible(nil) leSetLayerVisible(list(\"NW\" \"drawing\") t) hiRedraw()")
Details of the KEYS
The idea is to turn on CO layer and turn off all the other layers when the \ key is pressed on the keyboard
The idea is to turn on NW layer and turn off all the other layers when the ` key is pressed on the keyboard
The below code which turns on M1 layer and turns off all the other layers when 1 key is pressed on the keyboard works fine
hiSetBindKey("Layout" "<Key>1" "leSetAllLayerVisible(nil) leSetLayerVisible(list(\"M1\" \"drawing\") t) hiRedraw()")
Arokia
    The first needs to be:
    hiSetBindKey("Layout" "<Key>\\" "leSetAllLayerVisible(nil) leSetLayerVisible(list(\"CO\" \"drawing\") t) hiRedraw()")
    (i.e a double backslash). Otherwise the quote is escaped, and the two bindkeys will get messed up. Once I do that, both bind keys work fine.
  • Arokia
    Arokia over 3 years ago in reply to Andrew Beckett
    Thank you kindly, it worked.
