  3. sevAddExpression on netname called from some function
  • Views 6992
Ejcxuralsshdd
Ejcxuralsshdd over 3 years ago
I am trying to add expression using following code presetend in one of the post
sevAddExpression(sevSession(hiGetCurrentWindow()) "thing" "VT(\"/out\")")
It work but if net is coming from some function call (e.g. mynetname=CSSgetHierchicalnetname();)
Now I cant use mynetname variable inside sevAddExpression. I tried using printf inside SevaddExpression but it doenst work.
Any advice ?
    Andrew Beckett over 3 years ago +1
    Not sure what this CSSgetHierchicalnetname function does, but I assume you'd do something like: sevAddExpression(sevSession(hiGetCurrentWindow()) "thing" lsprintf("VT(%L)") mynetname)) Andrew
