  3. bindkey statement for Toggle between "USED" check box
  • Views 3024
Arokia
Arokia over 3 years ago
Hi All,
Please help me with a bindkey statement for Toggling between "check boxing" the "USED" layers and "Uncheck boxing" the "USED" layers check box.
Currently I'm using the below statements. ie F10 for checkboxing, and ctrl+F10 for uncheckboxing, is there a way when I press F10 once it will "checkbox" and after pressing F10 again it will uncheck box?
hiSetBindKey("Layout" "<Key>F10" "pteShowUsedLPP(t)")
hiSetBindKey("Layout" "ctrl<Key>F10" "pteShowUsedLPP(nil)")
Arokia Bharat
    Arokia,
    Use pteToggleShowUsedLPP() instead of pteShowUsedLPP(t/nil).
  • Arokia
    Arokia over 3 years ago in reply to Andrew Beckett
    Wow works beautifully ! Thank you !
  • Arokia
    I also went on ahead to apply your concept for the "Routing" checkbox
    hiSetBindKey("Layout" "<Key>F12" "pteToggleShowRoutingLPP()")
    it also worked ! Thanks a bunch !
  • Arokia
    On that note is there also a way to toggle between making a Layout "Editable" and making a layout "Read only"
    hiSetBindKey("Layout" "<Key>F7" "_leChangeEditMode("a" t)")
    hiSetBindKey("Layout" "ctrl<Key>F7" "_leChangeEditMode("r" t)")
    But I got syntax error
    Arokia
    Andrew Beckett over 3 years ago in reply to Arokia
    Arokia,
    Using public functions:
    hiSetBindKey("Layout" "<Key>F7" "geChangeEditMode(if(geGetEditCellView()~>mode==\"r\" \"a\" \"r\"))")
  • Arokia
    Thank you, helped a lot
