  3. taking list and strings as a input
  • Views 10190
SureshT
SureshT over 3 years ago
Hello all,
I am new to SKILL. And I want to take list and strings as an input from a user and sort it.
Please guide me, If any functions or procedures are available.
I am using Virtuoso 6.1.7 64b version
  • AaronSymko
    AaronSymko over 3 years ago in reply to SureshT +2
    The most common way is to use a Form with a string field, in which each item is space or comma separated. For example: procedure ( GetStringAsList() let ((stringField topLayout formId) stringField…
  • RobMan
    RobMan over 3 years ago
    The 'sort' function is probably your best starting point...
        Cadence SKILL Language Reference -- sort
  • SureshT
    SureshT over 3 years ago in reply to RobMan
    How to take list as a input from user?
  • SureshT
    SureshT over 3 years ago in reply to SureshT
    Thank you for your quick reply
  • AaronSymko
    procedure( GetStringAsList()
      let((stringField topLayout formId)
        stringField = hiCreateStringField(
          ?name 'stringField
          ?prompt "Enter Strings:"
          ?value ""
        topLayout = hiCreateFormLayout('topLayout
          ?items list(stringField)
        formId = hiCreateLayoutForm('TheForm "Input String(s)" topLayout
          ?callback 'GetStringAsListCB
          ?buttonLayout 'OKCancelDefApply
          ?unmapAfterCB t
          ?dialogStyle 'modal
        hiDisplayForm(formId)
        ;; Return the list
        formId->sortedList
      ); let
    ); procedure
    procedure( GetStringAsListCB(formId)
      let((stringVal sortedList)
        stringVal = formId->stringField->value
        if(blankstrp(stringVal) then
          hiHighlightField(formId 'stringField 'error)
          hiSetCallbackStatus(formId nil)
        else
          sortedList = sort(parseString(stringVal " ,:") 'alphalessp)
          info("Sorted List = %L\n" sortedList)
          hiSetCallbackStatus(formId t)
        ); if
        formId->sortedList = sortedList
      ); let
    ); procedure
    sortedList = GetStringAsList()
    • Vote Up +2 Vote Down
  • SureshT
    Thanks for your reply AaronSymko,
    Here in this example you have used a form but is there any other simple way like scanf in C programming
