  3. How to Display CIW output in Forms as log
  • Views 9909
Tejaskill
Tejaskill over 3 years ago
Hi all,
I am using ICADVM20.1, I have created a form using hiCreateAppForm() but I want to see the CIW output in that form as a output log. Is there any way to achieve this.
Thanks in advance.
Teja.
  • AurelBuche
    AurelBuche over 3 years ago +1
    Hi Teja, It depends what you actually want : - If you want to run a callback and display all the messages from the start to the end of the operation in your GUI, this is quite simple You can either…
  • AurelBuche
    Hi Teja,
    You can either redirect poport, woport and errport temporarily using outstring function, or if you want this data to be also printed in the CIW / CDS.log, you can use hiStartLog and hiEndLog then you just have to fetch the content of the custom log to print it in your GUI
    - If you want a log that gets updated with whatever is going-on during your Virtuoso session, this will be more tricky but might be achievable using a child process calling tail -f  or also using FIFO files
    Hope this helps,
    Cheers
    Aurélien
  • Tejaskill
    Tejaskill over 3 years ago in reply to AurelBuche
    Hi Aurélien
    Thanks for the reply.
    Below is my code...
    tkstring=hiCreateStringField(
    ?name 'TK1
    ?prompt "Enter Your Name"
    ?value ""
    tkstring1=hiCreateStringField(
    ?name 'TK2
    ?prompt "Enter Your Age"
    ?value ""
    form=hiCreateAppForm(
    ?name 'TKform
    ?formTitle "Test Form"
    ?fields list(tkstring tkstring1)
    ?callback "subprogram()"
    procedure(subprogram()
    printf("Your Name is %s\n" form->TK1->value)
    printf("Your Age is %s\n" form->TK2->value)
    hiDisplayForm(form)
    This will print some lines in the CIW, I want that lines to be printed as log attched to that form only.
    I mean Is there any way to create a string field or a text field to which we can pass the output of CIW into those fields.
    I am asking a little much, Could you please give me an example Slight smile.
    Regards
    Teja.
  • AurelBuche
    AurelBuche over 3 years ago in reply to Tejaskill
    Hi Teja,
    Here is an example that should do what you want  (I refactored your code a little bit) :
    ;; It is easier to use `hiCreateLayoutForm', `hiCreateFormLayout' `hiCreateVerticalBoxLayout'
    ;; and `hiCreateHorizontalBoxLayout' rather than `hiCreateAppForm'.
    ;; The layouts are calculating all the fields position automatically
    hiCreateLayoutForm( 'TKform "Test Form"
      hiCreateFormLayout( 'main_layout ?items list(
          ;; Instead of creating the fields, storing them into variables then use the variable
          ;; I prefer to place them directly and access them using their name. (Less code, less bugs)
          hiCreateStringField( ?name 'TK1        ?prompt "Enter Your Name" ?value "")
          hiCreateStringField( ?name 'TK2        ?prompt "Enter Your Age"  ?value "")
          hiCreateMLTextField( ?name 'output_log ?prompt "Output Log"      ?value "" ?editable nil)
      ;; lambda functions are more flexible than strings when using from callbacks
      ?buttonLayout 'ApplyCancel
      ?callback
      lambda( (@rest _args)
        ;; Create an outstring port and safely store previous ports value so they can be reverted back
        let( ((port        (outstring))
              (old_poport  poport     )
              (old_woport  woport     )
              (old_errport errport    )
           ;; `unwindProtect' is required to guarantee main ports are always restored afterwards
           unwindProtect(
             progn(
                   poport  = port
                   woport  = port
                   errport = port
                   subprogram()
                   TKform->output_log->value = getOutstring(port)
             progn(
                   poport  = old_poport
                   woport  = old_woport
                   errport = old_errport
                   close(port)
           );unwindProtect
        );let
      printf("Your Name is %s\n" TKform->TK1->value)
      printf("Your Age is %s\n"  TKform->TK2->value)
    hiDisplayForm(TKform)
  • AurelBuche
    AurelBuche over 3 years ago in reply to AurelBuche
    Regarding my previous answer
    This is a way to achieve what you want when you are running another program for which you do not control the ouput
    If the subprogram is written by yourself it would be much safer and cleaner to write a custom `print_to_log' function to replace your calls to `printf'
    Then inside this function you print the messages to whatever you want : the CIW, the field, an outstring, a file etc.
