  3. Bindkey for turning off the "Cross Cursor" in Layout
  • Replies 7
  • Subscribers 153
  • Views 5730
Arokia
Arokia over 3 years ago
Hi Team,
May I please know how to turn off the "Cross cursor" in Layout using bindkey
I've tried the below, but it does not work for me
hiSetBindKey("Layout" "ctrl<Key>z" "leDisplayOptionsForm->options->cursorShape->value =  nil")
I've also tried the below
hiSetBindKey("Layout" "ctrl<Key>z" "leHiEditDisplayOptions(\"options\;cursorShape\" nil \"Objects\")")
But still nothing happens.
Arokia
  • shoefly
    shoefly over 3 years ago +1
    Hi Arokia, If you are adamant about turning "Cross Cursor" off, this should work: hiSetBindKey("Layout" "ctrl<Key>z" "hiGetCurrentWindow()->cursorShape=nil") Keep in mind that this is just a window…
  • shoefly
    Hi Arokia,
    Keep in mind that this is just a window-specific setting. If you want a global setting, you may want to add a setting in the .cdsenv to automatically keep Cross Cursor off.
    Of course, as a devout Andrew Beckett fangirl, I would be remiss if I did not warn you of a caveat when using the envSetVal. It is what he has referred to as "the last resort" for the lookup when opening a new window. Priority is the cellView's properties; if there are no relevant cellView properties, then the library's props are priority. If there are no relevant library props, then the technology library's properties are priority; if those are non-existant, then the .cdsenv finally gets to shine.
    Good luck - I'm cross-(cursor)-ing my fingers that this works for you & that you have fun exploring customizations!
    -J
  • Arokia
    Arokia over 3 years ago in reply to shoefly
    Wow, this worked, but when I tried the same for the dimming option it did not work Disappointed
    I tried the below.
    hiSetBindKey("Layout" "<Key>F12" "hiGetCurrentWindow()->enableDimming=nil")
    Arokia
  • Arokia
    Arokia over 3 years ago in reply to Arokia
    This worked though
    hiGetCurrentWindow()->dimmingOn=t
    or
    hiGetCurrentWindow()->dimmingOn=!hiGetCurrentWindow()->dimmingOn
    But now I wonder how to turn on Automatic dimming checkbox?
    Tried the below but did not work
    hiGetCurrentWindow()->dimmingAutoEnable=t
    Arokia.
  • mschw
    mschw over 3 years ago in reply to Arokia
    Dear Arokia,
    i think it is hiGetCurrentWindow()->dimmingAutoEnabled and not hiGetCurrentWindow()->dimmingAutoEnable.
    You can list  all properties of the window in the CIW with hiGetCurrentWindow()->?.
    In addition, maybe this article can help you out.
    Matthias
  • Arokia
    Arokia over 3 years ago in reply to mschw
    Sadly both the below commands don't work
    hiSetBindKey("Layout" "<Key>F1" "hiGetCurrentWindow()->dimmingAutoEnable")
    hiSetBindKey("Layout" "<Key>F12" "hiGetCurrentWindow()->dimmingAutoEnabled")
    Arokia
  • AurelBuche
    AurelBuche over 3 years ago in reply to Arokia
    That is because "hiGetCurrentWindow()->dimmingAutoEnabled" does nothing except returning the value of dimmingAutoEnabled in the current window
    You should set it either to t or !hiGetCurrentWindow()->dimmingAutoEnabled ...
    hiSetBindKey("Layout" "<Key>F12" "hiGetCurrentWindow()->dimmingAutoEnabled=t")
  • Arokia
    Arokia over 3 years ago in reply to AurelBuche
    My Bad, yeah, after including =t, it worked. Thanks Slight smile
