  3. Bindkey statement for toggling Transparent group.
  • Views 8402
Arokia
Arokia over 3 years ago
Hi Team,
Need help writing a bindkey statement for toggling TRANSPARENT GROUP on/off
For example I tried the below.
hiSetBindKey("Layout" "<Key>F1" "swindow(31)->hiToolbars->lebOptionsToolbar_31->lebTrans->checked=nil")
hiSetBindKey("Layout" "<Key>F12" "swindow(31)->hiToolbars->lebOptionsToolbar_31->lebTrans->checked=t")
It works but its only for a particular window, and also it uses two bindkeys.
Do I need to use the above statement together with the hiGetCurrentWindow() statement to make the bindkey work for all the Layout windows?
Arokia
  • RobMan
    RobMan over 3 years ago +2
    Setting 'transparentGroup' is only valid for the current window. i.e. You can have a different setting for different layout windows, You could use a simple toggle like this ... hiSetBindKey("Layout"…
  • AurelBuche
    AurelBuche over 3 years ago +1
    Hi Arokia, This is probably not the best way to do but should work : hiSetBindKey("Layout" "<Key>F12" "(deFindToolbar 'lebOptionsToolbar (hiGetCurrentWindow))->lebTrans->checked = !(deFindToolbar …
  • AurelBuche
    Hi Arokia,
    hiSetBindKey("Layout" "<Key>F12" "(deFindToolbar 'lebOptionsToolbar (hiGetCurrentWindow))->lebTrans->checked = !(deFindToolbar 'lebOptionsToolbar (hiGetCurrentWindow))->lebTrans->checked")
  • RobMan
        hiSetBindKey("Layout" "<Key>F1" "hiGetCurrentWindow()~>transparentGroup = !hiGetCurrentWindow()~>transparentGroup")
    FYI; There is an envar you can set on startup...
      envSetVal("layout" "transparentGroup" 'boolean t)
    ..But this doesn't work "on the fly".
    • Vote Up +2 Vote Down
  • Arokia
    Arokia over 3 years ago in reply to AurelBuche
    Works perfectly, thanks Slight smile
