  3. Getting a Blunder while using dbFlattenInst()
  • Subscribers 150
  • Views 9161
Tejaskill
Tejaskill over 3 years ago
Hi all,
I am using dbFlattenInst() function to flatten a cellview but after I have executed the code I am getting LVL errors with my previous version(hierarchy database).
I dont Know why it is doing like this, Is there anything I should check about the dbFlattenInst() or the layout options.
My code is
cv=geGetEditCellView()
foreach(inst cv~>instances dbFlattenInst(inst 32 t nil nil nil t nil t))
Thanks in advance,
Teja.
    Teja,
    By "LVL" do you mean XOR? What kinds of errors are you seeing? This is rather hard to explain without any kind of details...
  • Tejaskill
    Tejaskill over 3 years ago in reply to Andrew Beckett
    Yes I mean XOR I am getting METAL1 VIA1 and METAL2 geometric difference.
    Teja.
    Andrew Beckett over 3 years ago in reply to Tejaskill
    A picture would help. It's rather hard to guess what's wrong with just a description.
  • Tejaskill
    Hi Andrew
    I have a layout view and I saved a copy as layout_x view and executed the code for layout_x view
    Then I have completed the XOR run between layout view and layout_x view using assura >> here is the resiult of geometric difference
    Teja.
    Teja,
    I'm not sure whether you're being intentionally evasive here, but a picture which just shows a screenshot of the Assura output is not any more helpful than the text you included before (it just says the same thing in a screenshot!). A picture of the layout would be rather more informative highlighting the actual differences.
    My guess was that this might be some gridding problem - something which was off-grid being snapped during the flatten. I'd wondered whether if the centre of a via was off-grid, and the width of the cut was an exact database unit  that this could happen, but I've not managed to reproduce that (I didn't spend too long trying because I'm just guessing and I'd sooner not waste time on guesswork).
    Which IC sub-version are you using? Which technology (PDK) are you using?
