  3. ?keepOut in rodFillWithRect()
  • Subscribers 152
  • Views 8436
GoodHarry
GoodHarry over 3 years ago
I want to use ?keepOut in rodFillWithRect() to create a excluded polygon in master Rect.
what's the parameters for   ?keepOut  ?
It can not work when providing a list of points for ?keepOut as Candance Help descripted.
who can tell me what parameters should be provided?
Best Regard
code as below:
  • skillUser
    skillUser over 3 years ago
    The ?keepOut argument needs to be a list of lists, the error message states this: ... Specify a list of keepouts, where a keepout is a list of points.
    Try changing the excludeList, for example:
    excludeList = list(list(list(0.15 -0.15)
    list(0.15 0.15)
    list(10.0 0.15)
    list(10.0 -0.15)
    list(0.15 -0.15))
    Having said this, when I tried the correct format the rodFillWithRects() function did not seem to exclude the rects from that area.
    Hopefully this helps though.
    Best regards,
    Lawrence.
  • GoodHarry
    GoodHarry over 3 years ago in reply to skillUser
    Hi Lawrence,
    Thanks for your answer, the error is cleaning.
    as you said, the ?keepOut don't exclude a area from master rect.
    may be I need try other skill function.
    Thanks anyway.
    Best Regards,
    Harry
    Andrew Beckett over 3 years ago in reply to GoodHarry
    The ?keepOut argument does work, but you must also specify ?outputFillShape. This is explained in Change in functionality of ROD function rodFillWithRects with keepOut option in IC6.1.7 ISR11. Example SKILL commands for dbCreateViaShapeArray.
    I've requested that the documentation is fixed (it doesn't make this clear); you should be able to make your example work (with Lawrence's suggestion) by adding ?outputFillShape list(nil) to the argument list of rodFillWithRects
  • GoodHarry
    GoodHarry over 2 years ago in reply to Andrew Beckett
    Thanks for your reply.
    It helps me a lot in my work.
    B&R
    Harry
  • GoodLarry
    GoodLarry over 2 years ago
    Thanks for your post.
    I had the same problem and now I found the solution.
    Best
    Larry
