  3. Problem with rodCreatePath function
  • Subscribers 152
  • Views 8345
GabrielVarela
GabrielVarela over 3 years ago
Hi!
I'm working on a custom PCELL that uses rodCreatePath to draw some connections but I've encountered myself with a weird behavior. When using the offset parameter of it, sometimes it doesn't draw the path as expected.
This is the test case I've prepared to show my problem:
First I define the following list of points:
 path= list(0:0 0:50 -10:60)
And then with different "Offset" values I call the rodCreatePath like this:
rodCreatePath(
?layer list("M1" "drawing")
?width 15.0
?pts path
?offset Offset
?justification "center"
?endType "flush"
?cvId geGetEditCellView()
When using an offset of 50 (the same length of the vertical path in the original path) it doesn't work as I've expected.
Any help will be appreciated, thanks.
Gabriel
  • mbracht
    mbracht over 3 years ago
    Hi Gabriel,
    First of all your screenshot above doesn't reflect a path with the points (0:0 0:50 -10:60). If I create this rod Path with no offset at all with your point list I get this:
     rodCreatePath(
         ?width 15.0
         ?pts path
         ?offset 0.0
         ?endType "flush"
    Subsequently increasing the offset (and reducing the width to 5.0 for better visibility's sake) I get this
    (foreach offset (list 10.0 20.0 30.0 40.0 50.0)
       rodCreatePath(
         ?width 5.0
         ?pts path
         ?offset offset
         ?endType "flush"
    And this is exactly what I would expect...
    Max
  • GabrielVarela
    GabrielVarela over 3 years ago in reply to mbracht
    You are right, I made an error while typing, the correct list of points is list(0:0 0:50 10:60).
    I´ve repeated the test using your function call (with the list that I mentioned above) and I get this:
  • mbracht
    mbracht over 3 years ago in reply to GabrielVarela
    hmmmh...I see the same behavior now and I cannot explain it. In fact it does work for 49.9 and also for 50.1. Maybe it's some rounding effect. I recommend to open a customer support case.
  • GabrielVarela
    I'll do, thanks for your time!
