  3. Getting Selected Maestro Output with SKILL
  • Views 8005
epmurphy
epmurphy over 3 years ago
I want to get the name of a selected output in a Maestro session in a SKILL Script. In other words, when the user clicks one of the outputs, I want to store the "details" column of the selected row in a variable. The CIW shows this method when an output is selected (row 130, column 3):
"_axlOutputsSetupSelectItem(axlOutputsForm0->axlOutputsWidget0 "'( (130 3))")"
Is there any documentation on this function or a way to query the value?
    That function is private (the clue is the leading underscore). There are no public functions (as far as I know) to get the selected cell (or cells) from the outputs setup tab. There is the maeGetResultsViewSelectedCellsDetails function to get the selected result cells from the results pane, but nothing similar for the output setup pane.
