  3. Missing the buttonLayout of a form that docked in a doc...
  • Views 7791
Missing the buttonLayout of a form that docked in a dockWindow
GenoJohnking
GenoJohnking over 3 years ago
Hi ALL,
I have a lot of forms showed by clicking buttons, it's a bother that so many forms covers the whole screen, so I'm about to reduce the form's number by dock window(hiCreateWindow, hiCreateDockWindow)
I found that the button layout of a form will disapear that the form docked. So I  want to know that how to keep the button layout of a form even it docked.
Virtuoso 6.18.0, Here is example code and screenshot:
Code:
procedure( popupform()
    let( (fileLocation loadFileButton )
        fileLocation = hiCreateFileSelectorField(
                ?name           'fileLocation
                ?mode           'existingFile
                ?prompt         "Choose a file"
                ?editable       t)
        loadFileButton = hiCreateButton(
                ?name           'loadFileButton
                ?buttonText     "Load File"
                ?callback       "printf(\"Loading file from popup form %s\n\" myForm->fileLocation->value)")
        myForm = hiCreateAppForm(
                ?name           'myForm
                ?formTitle      "My Form which should be popup"
                ?buttonLayout   'Close
                ?dontBlock t    ; with this your previous code would have failed
                ?fields         list(
                                      list(fileLocation 10:10 400:20 100)
                                      list(loadFileButton 415:10 80:30)
                ?unmapAfterCB           t)
        myForm
    ); let
procedure( dockform()
    let( (sww1 sw1 w1 dform )
        dform = popupform()
        sww1 = hiOpenWindow(
                ?bBox list(30:30 500:500)
                ?type "graphics"
        sw1 = hiGetSessionWindow(sww1)
        w1 = hiCreateDockWindow(
                        ?appType        "Docked Form"
                        ?widgetType     "form"
                        ?handle         'dockedForm
                        ?title          "Docked Form"
                        ?form           dform
        myDock = hiDockWindow(
                        ?window         w1
                        ?session        sw1
                        ?side           'right
    ); let
dockform()
  • AurelBuche
    AurelBuche over 3 years ago
    A form window does not show the buttonLayout of the form it contains.
    If you want it to show, you will have to recreate it by hand using hiCreateButton or hiCreateButtonBoxField
    I suppose you will have to change the callbacks if you want to close the window in the same time because hiFormClose might not be sufficient
    Cheers
    Aurélien
  • GenoJohnking
    GenoJohnking over 3 years ago in reply to AurelBuche
    Thanks AurelBuche.
    I understood that missing the layout of the form that docked in the dockwindow is expected baheior.
    Geno
