  3. OCEAN script only works on re-evaluation
  • Subscribers 152
  • Views 9361
imulsion
imulsion over 3 years ago
Hi all,
I have an OCEAN script added to my simulation outputs, which I need to do the following (per corner):
- Detect when a particular signal crosses a threshold
- Take that crossing point and add it to the current corner as one of the corner parameters
Here is what I have:
axlAddOutputs(list("Success/Fail"))
sess = axlGetWindowSession()
sdb = axlGetMainSetupDB(sess)
crnr_name = axlGetCornerNameForCurrentPointInRun()
crnr_handle = axlGetCorner(sdb, crnr_name)
openResults()
trim_val_s = aelEngNotation(round(cross(VS("/vref_out") 1.204 1 "either" nil nil nil)))
putvar = axlPutVar(crnr_handle "trim_val" trim_val_s)
if(putvar == nil then s_f = 0 else s_f = 1)
axlOutputResult(s_f "Success/Fail")
As you can see, it simply updates the current corner by accessing the appropriate corner handle.
This solution isn't perfect. When I run my simulations, the script always results in eval err when executing axlGetMainSetupDB, because axlGetWindowSession returns nil. However, if I re-evaluate the outputs (all/full as opposed to incremental/partial), the script runs fine and the corners are updated.
Is there any explanation for why axlGetWindowSession might return nil? Am I going about this the wrong way? Is there a better solution?
I'm on sub-version IC6.1.8-64b.500.31
Many thanks
    Andrew Beckett over 3 years ago in reply to imulsion +1
    I get why you've done it this way - it's probably simpler than the alternative which is to use the maeReadResDB() function to get a handle and then iterate over the results (I'd have a scalar result value…
    ShawnLogan over 3 years ago
    Dear imulsion,
    Does the use of the following verbose form of the command provide a response of "nil" on the first attempt to run your script?
    axlGetWindowSession( hiGetCurrentWindow())
    Shawn
    That's not a valid thing to do in an OCEAN script output. For a start, the script is run at each sweep point/Monte Carlo point/corner (or combinations of the above), and it's not going to work when simulations are running because the scripts (as are other output expressions) are run in a background process (either a background virtuoso if using ICRP or a background expression evaluator if using LSCS) and there's no "window" for axGetWindowSession to retrieve. That's also no axl/mae session in those background sessions because it would be locked by the parent virtuoso - so even if you could find a way of getting a session it wouldn't be able to write to it. This will therefore only work when running a single simulation (because single point optimisation in the job policy runs everything in the virtuoso session itself, at least for ICRP), or when doing re-evaluation (and even then, not when using the new distributed re-evaluation that's available in Virtuoso Studio IC23.1).
  • imulsion
    imulsion over 3 years ago in reply to Andrew Beckett
    Thanks for your reply. The reason I opted for this approach is so I could use axlGetCornerNameForCurrentPointInRun() (otherwise I couldn't think of a way to apply each trim code to each corner). Is there an alternative approach that is less "hacky", or is this kind of thing not really possible?
    Cheers
    I get why you've done it this way - it's probably simpler than the alternative which is to use the maeReadResDB() function to get a handle and then iterate over the results (I'd have a scalar result value to make it easier to find rather than needing to read waveform data) and then update the corners that way - and run this manually after simulation whenever you want to update the corner settings. What you've done is a bit more self-contained, but it just can't work at run time without needing a re-eval.
  • imulsion
    That makes a lot of sense. I'll stick with my current method, even though it doesn't quite work it's probably the easiest way of doing it (at the very least it executes automatically!)
    Thanks very much for your time
    Cheers
