  3. Need a script where traversing can be stopped based on level...
  • Views 6743
Need a script where traversing can be stopped based on level in layout.
BabaiVLSI
BabaiVLSI over 3 years ago
Hello All,
I need to develop a script where net with specific name or instance with specific cell name in down the hierarchy will get highlighted. I need to stop searching based on level of hierarchy (suppose I shall do the search execution till level 2, then it will not search below level 2).
I got a great help from following script given by Andrew Beckett, where I can't think of implementing stop level in this script. Please help me.
community.cadence.com/.../finding-of-polygons-skill
    In the context of the code in that example script, you could do this by adding an additional argument in the function definition (differences in red):
    procedure(CCFoutputPolygonCentres(cvId myPort @key
      (objType "polygon") (layerName "metal1")
      (transform list(0:0 "R0" 1)) (stopLevel 32)
    Then around each of the recursive calls to CCFoutputPolygonCentres you'd do something like this:
      foreach(inst cvId~>instances
        when(inst~>objType=="inst" && stopLevel>0
          CCFoutputPolygonCentres(inst~>master myPort
            ?objType objType ?layerName layerName ?stopLevel stopLevel-1
            ?transform dbConcatTransform(inst~>transform transform)
    (the second recursive call is in the mosaic loop further down, and a similar condition would be needed there)
    Now when you call CCFoutputPolygonCentres() yourself, you could call it with ?stopLevel 2 (for example).
