  3. cdsFinder command not found
  • Replies 8
  • Views 10257
dietSprunk
dietSprunk over 3 years ago
I'm beginning the SKILL Language Programming Introduction vIC6.1.8 / ICADVM20.1 course and the first command entry doesn't seem to work.
I'm entering cdsFinder & into a terminal window and I'm getting command not found.  Is there a special directory I should be entering this into?
As an aside, I'm able to open the SKILL API Finder through the Virtuoso CIW using both the pulldown menu and the startfinder() command, but I'd like to try to resolve this issue separately, just in case there are other commands that I will need to use in the future that I won't knowingly be able to circumvent through the use of the CIW.
    Andrew Beckett over 3 years ago in reply to mbracht +1
    Hi Max, The fact that it works with startFinder() suggests that it can be run; most likely dietSprunk 's environment is using wrappers around executables (such as virtuoso) and there's no wrapper around…
  • mbracht
    mbracht over 3 years ago in reply to Andrew Beckett +1
    Hi Andrew...I don't quite understand this - I mean he must have been able to launch virtuoso so tools/dfII/bin must be in the PATH but not necessarily tools/bin. But then again I have to say I never tried…
  • mbracht
    mbracht over 3 years ago in reply to dietSprunk +1
    this is definitely a wrapper - the normal way to launch virtuoso is well...just typing virtuoso
  • mbracht
    HI,
    Most likely the directory containing the cdsFinder executable is not in your Unix PATH. The cdsFinder is contained in the tools/bin directory of your IC installation.
    Can you make a
    % echo $PATH
    ...and see what you get.
    Max
  • mbracht
    mbracht over 3 years ago in reply to mbracht
    you also need to have a korn shell (ksh) installed. The cdsFinder is a symbolic link to cdnWrapper which happens to be a ksh script.
    Hi Max,
    The fact that it works with startFinder() suggests that it can be run; most likely dietSprunk's environment is using wrappers around executables (such as virtuoso) and there's no wrapper around cdsFinder...
  • mbracht
    Hi Andrew...I don't quite understand this - I mean he must have been able to launch virtuoso so tools/dfII/bin must be in the PATH but not necessarily tools/bin. But then again I have to say I never tried to run virtuoso without tools/bin in the PATH.
  • dietSprunk
    dietSprunk over 3 years ago in reply to Andrew Beckett
    If I type cds61 into a terminal window, Virtuoso 6.1.8 boots up fine.  Is that the normal command to launch Virtuoso 6.1.8, or is that a wrapper?
    Also, I looked in the bin directory where cds61 exists, but there's no cdsFinder command.  Is this a question that I should be asking my IT department?
  • mbracht
    Max - it's not unusual for some customers to have a wrapper script (which might even be called "virtuoso" (not in this case, where it's cds61)) which takes care of setting the $PATH, $CDS_LIC_FILE, other things in the environment and then calls the real virtuoso. They may not have the IC installation directly in the path, and so unless a wrapper is provided for cdsFinder too, there's no way to find it...
    cds61 is something provided by your CAD/IT department dietSprunk, so you may want to ask them to provide a way of launching that from a terminal window too.
  • dietSprunk
    Ok. Will do. Thank you for the help.
