  3. need help with this label rotate function
  • Views 7722
JJAP
JJAP over 3 years ago
Can you help this label rotate function. this code is working, other than orient, I wanted to add justify function as well because when the labels got rotated (R180), the label will be "flipped" and I want to correct it.
here's the code:
procedure(rotate_toggle()
foreach(fig geGetSelSet()
when(fig~>orient
fig~>orient =case(fig~>orient
("R0" "R90" )
("R90" "R180" )
("R180" "R270" )
("R270" "R0" )
(t fig~>orient )
);procedure
Sorry I'm new to skill code programming. I saw this posted by Andrew B., this is what I would like but just use 1 bindkey to cycle to the options.
car(geGetSelSet())~>justify="centerRight" car(geGetSelSet())~>orient="R90"
car(geGetSelSet())~>justify="centerRight" car(geGetSelSet())~>orient="R0"
car(geGetSelSet())~>justify="centerRight" car(geGetSelSet())~>orient="R270"
car(geGetSelSet())~>justify="centerLeft" car(geGetSelSet())~>orient="R0"
  • AurelBuche
    AurelBuche over 3 years ago
    The following snippet should work out of the box. (Even though It might be over-complicated if you are new to SKILL)
    ;; SKILL++ is required so the defined function can always access the following variable
    (inScheme
      (let ((infinite_loop
              '(("centerRight" "R90" )
                ("centerRight" "R0"  )
                ("centerRight" "R270")
                ("centerLeft"  "R0"  )
        ;; Build infinite loop from list by making it point to itself
        (nconc infinite_loop infinite_loop)
        (defun get_selected_labels ()
          "Return currently selected labels"
          (setof obj (geGetSelectedSet) (equal "label" obj->objType)))
        (defglobalfun custom_cycle_label_orients ( @key  (labels (get_selected_labels))
                                                   @rest _args
          "Cycle through a list of predefined orient/justification pairs and set them to LABELS"
          (destructuringBind (justify orient) (pop infinite_loop)
            (foreach label labels
              (setf label->justify justify)
              (setf label->orient  orient )
          t)
        ));scheme closure
    (hiSetBindKey "Layout" "<Key>F5" "custom_cycle_label_orients")
    If you are eager for any explanation, I'll be happy to detail how it works
    Hope this helps,
    Cheers
    Aurélien
  • JJAP
    JJAP over 3 years ago in reply to AurelBuche
    Thanks Aurélien! I tested it and it works!
