  3. Missing Frame Titile of layout in layoutForm
  • Views 7480
GenoJohnking
GenoJohnking over 3 years ago
Hi All,
I noticed that the title of frame can not dispalyed if there is only one gridLayour/verticalLayout/... , only if there is at least two gridLayour/verticalLayout/... in layoutForm will be showed the frame title.
So is there a way to show title of frame that only one gridLayour/verticalLayout/...
Code example(all form Master Andrew)
;;Code 1 , missing the title of frame
procedure(abCreateBigLayoutForm(numFields)
    let((fields field label gridLay)
        for(i 0 numFields
            field=hiCreateStringField(?name concat('myfield i))
            label=hiCreateLabel(?name concat('label i) ?labelText
                sprintf(nil "Field %d" i)
            fields=tconc(fields list(label 'row i 'col 0))
            fields=tconc(fields list(field 'row i 'col 1))
        fields=tconc(fields list('col_stretch 0 0))
        fields=tconc(fields list('col_stretch 1 1))
        fields=car(fields)
        gridLay=hiCreateGridLayout(
            'gridLay
            ?items fields
        hiCreateLayoutForm(
            'abBigLayoutForm
            "Big layout form"
            ; Add a stretchable region below the grid so that
            ; the fields don't spread out vertically
            hiCreateVerticalBoxLayout(
                'vbox
                ?frame "test frame"
                ; ?frame t
                ?items list(
                    gridLay
                    list('stretch_item 1)
            ?minSize 600:200
abCreateBigLayoutForm(10)
hiDisplayForm(abBigLayoutForm)
;;Code 2, with two frame title
procedure(abCreateFrameLayoutFields(startNum endNum)
    let((fields field label)
        for(i startNum endNum
        fields=car(fields)
procedure(abCreateFrameLayoutForm()
    let((fields frameLay1 frameLay2)
        fields=abCreateFrameLayoutFields(0 3)
        frameLay1=hiCreateGridLayout(
            'frameLay1
            ?items fields
            ?frame "With Title"
        fields=abCreateFrameLayoutFields(4 6)
        frameLay2=hiCreateGridLayout(
            'frameLay2
            ?items fields
            ?frame "Title two"
        hiCreateLayoutForm(
            'abFrameLayoutForm
            "layout form with frames"
                'vbox
                ?items list(
                    frameLay1
                    frameLay2
            ?minSize 600:200
hiDisplayForm(abCreateFrameLayoutForm())
Geno
    Geno,
    If you change the hiCreateGridLayout within abCreateBigLayoutForm to:
                'gridLay
                ?items fields
    	    ?frame "Only one"
    then you get a frame around that layout - and there's only one. So I don't understand what you're saying - maybe I'm missing something. The code as you shared it doesn't have a frame title because the code wasn't using ?frame - nothing to do with the fact that there was only one layout.
  • GenoJohnking
    GenoJohnking over 3 years ago in reply to Andrew Beckett
    Thanks, Andrew
    I know how to enable the frame of layout of a fromGrinning
