  3. Adding an image to a form, and other form questions
  • Replies 7
  • Views 10092
blankman
blankman over 3 years ago
Hi all, I’m trying to create a form using “hiCreateAppForm”, and trying to place an image in the form - I couldn't locate the relevant field function in the documentation. I believe this is possible as I’ve seen it done elsewhere. Is there a field function alongside the other field functions such as hiCreateButton etc, that allows for this to be done? Or is there another method that is typically used?
Also wondering,
  • using the “?maxSize” function, is it possible to constrain the form only to the X dimension, but allow the Y to be varied?
  • is it possible to keep the form on top of other Virtuoso windows?
  • and is it possible to open the form directly under the mouse?
Thanks in advance,
Kind rgds,
Brian.
  • blankman
    blankman over 3 years ago in reply to Andrew Beckett +1
    Thanks AurelBuche, also another way I'm now realizing: ?minSize 901:80 ?maxSize 901:632 Brian.
  • AurelBuche
    AurelBuche over 3 years ago
    To place images in your form you should use hiCreateLabel and hiCreate.., hypertext/HTML fields
    Then you can insert an image using HTMl syntax (it’s quite simple)
    about ?maxSize I am almost certain that it’s not possible to restrain the size in only one direction (maybe try with -1 or 0 but I don’t believe it will work)
    For the form on top of other windows and the startup position, this will mostly depend on your windows manager (windows, xfce, gnome etc.)
    Hope this helps
    cheers
    Aurelien
  • AaronSymko
    AaronSymko over 3 years ago in reply to AurelBuche
    Also, for opening a form directly under the last mouse click, you can supply a second argument to hiDisplayForm as -1:-1.  For example:
    hiDisplayForm(formId -1:-1)
  • blankman
    blankman over 3 years ago in reply to AaronSymko
    Thanks Folks, very helpful
  • AurelBuche
    AurelBuche over 3 years ago in reply to AaronSymko
    I did not know that -1:-1 would place it under the cursor. That's a really good info. Thanks !
  • AurelBuche
    AurelBuche over 3 years ago in reply to blankman
    Also for your ?maxSize issue, to restrain only in one direction you could simply use a huge value for the other one (bigger than the screen width/height)
    ?maxSize 500:10000 should do the job
    Andrew Beckett over 3 years ago in reply to AurelBuche
    Nor did I! It's always good to learn something new (good to see that it's documented behaviour, but I've not had any reason to look at the documentation about hiDisplayForm for a very long time)
  • blankman
    ?minSize 901:80
    ?maxSize 901:632
    Brian.
