  3. How to interact with ADE L window with skill code?
  • Views 8011
Maple Oven
Maple Oven over 3 years ago
I create a state with cellview and I want to edit its model Library and design parameters while I'm using it. How can I get the ADE L window and how to edit its property?
    First of all, I should point out that ADE L is end-of-lifed (replaced by ADE Explorer) and is not in the ICADVM20.1 or IC23.1 release - so you should move to using ADE Explorer.
    Here are the functions you'd need to use:
    You can get the current session using asiGetCurrentSession()
    ; get the models
    asiGetModelLibSelectionList(asiGetCurrentSession())
    ; add a model
    asiAddModelLibSelection(asiGetCurrentSession() "someFile.scs" "NN")
    ; asiRemoveAllModelLibSelection(asiGetCurrentSession()) if you want to remove all the models
    ; get the design variables
    asiGetDesignVarList(asiGetCurrentSession())
    ; add a couple of design variables
    asiAddDesignVarList(asiGetCurrentSession() list(list("var1" "20") list("var2" "30")))
    ; replace the variables rather than add
    asiSetDesignVarList(asiGetCurrentSession() list(list("var1" "20") list("var2" "30")))
  • Maple Oven
    Maple Oven over 3 years ago in reply to Andrew Beckett
    Thank you, Andrew!
