  3. How to get Windows Number? or how to Set a WIndow new Window...
  • Views 10335
How to get Windows Number? or how to Set a WIndow new Window number?
alaylayla
alaylayla over 3 years ago
Window : number,how i get and change the number?
I see the second number  in context  attribute is same as window numbe
what's meaning and function of context attribute in window ID ?
Virtuoso 618
  • AurelBuche
    AurelBuche over 3 years ago
    I don't believe that you can change the window id number, it is managed by Virtuoso directly
    To extract it, you can do the following :
    ;; My window shows 5(13) in its bottom left corner
    ;; It displays a schematic cellview and other dockable windows (also called assistants)
    ;; From support.cadence.com/.../ArticleAttachmentPortalt
    ;; "SKILL procedure to have only the window number returned"
    procedure( getWinNum()
       window=hiGetCurrentWindow()
       window->windowNum
    ;; Other solution is to extract the number directly from window representation
    (defun get_win_number (win)
      (atoi (cadr (parseString (lsprintf "%L" win) ":"))))
    ;; Current window (the one showing the cellview)
    win = (hiGetCurrentWindow)
    win->windowNum
    ;; => 13
    (get_win_number win)
    ;; => 13
    ;; Session window (it contains the main window and the dockable ones)
    swin = (hiGetSessionWindow win)
    ;; Unfortunately in my case the following does not work
    swin->windowNum
    ;; => -2147483643
    (get_win_number swin)
    ;; => 5
    Hope this helps
    Aurélien
    Andrew Beckett over 3 years ago in reply to AurelBuche
    Further to Aurélien's excellent feedback, most of the time you deal with windowIds (such as returned by hiGetCurrentWindow) - there aren't many cases where you need the window number. About the only scenario is if you need to construct a string callback (for something that doesn't support closures, say) which references a window id - in that case you might doing something like lsprintf("hiRaiseWindow(window(%d))" windowId->windowNum) .
    Why would you want t change the window number? You can't do this, but I'm intrigued as to why you might want to do this.
  • alaylayla
    alaylayla over 3 years ago in reply to Andrew Beckett
    Thanks !!!
    I just want to change the size of the winddow. I found that the hiRaiseWindow function needs the window number parameter; but I didn't find the window number parameter through "windowID~ >?"; that's why I wanted to use hiRaiseWindow by directly giving the window a new window number such as "999". Now, I know that you can get the window number through "windowID~ > windowNum", so I don't need to do that. But I'm very confused, why can't I see windowNum in the result returned by "window ID~ >?", I almost got the window number by getting the second number of the context parameter in windowID.
  • alaylayla
    alaylayla over 3 years ago in reply to AurelBuche
    tank you
    Andrew Beckett over 3 years ago in reply to alaylayla
    The hiRaiseWindow function does not need a window number. It needs a windowId such as returned by various functions such as deOpen(), geOpen(), hiGetCurrentWindow(), hiGetWindowList() etc.
    I agree that windowID->? doesn't list the built-in attributes such as windowNum - it only lists the user-defined properties on the window. That's a bit confusing, I agree entirely. However, as I mentioned before you rarely need to use the window number.
