  3. Is there a way to set bold string as button's text?
  • Views 3064
GenoJohnking
GenoJohnking over 3 years ago
Hi All,
I found that we can set bold text of label text, so I tried to set the bold text of button text use the same way, but it didn't works.
So I want to ask that is there a way to set the format of button text?
Code example:
procedure(bold()
let((lb1 )
  lb1 = hiCreateLabel(
    ?name 'lb1
    ?labelText "<b style='color:#cc0000;'>English</b>"
  ; lb2 = hiCreateLabel(
  ;   ?name 'lb2
  ;   ?labelText "<b style='color:#cc0000;'> labelText </b>"
  bt1 = hiCreateButton(
    ?name 'bt1
    ?buttonText ""
  form1 = hiCreateAppForm(
    ?name 'form1
    ?fields list(
      list(lb1 5:5 100:30)
      list(bt1 5:35 300:30)
  hiSetButtonLabel(form1~>bt1 "<b style='color:#cc0000'> labelText </b>")
  hiDisplayForm(form1)
bold()
Geno
    Hi Geno,
    This isn't supported with the text on buttons. Even with other fields it has to be used with care because it conflicts with some auto-scaling we have implemented for the older 2D forms (in other words you would need to be careful about not significantly changing font sizes). There's a change request (CCR 2249006) asking about buttonText support, but there's no plans for this currently.
  • GenoJohnking
    GenoJohnking over 3 years ago in reply to Andrew Beckett
    Thanks Andrew, I understood.
    Geno
