  3. Accessing regex capture group content
  • Views 7931
Zol
Zol over 3 years ago
Is there a way to return the content of the capture groups in a regex match? Below is an example, where I would like to capture the two numbers in the net name:
re = pcreCompile(".*<([0-9]+):([0-9]+)>")
a = pcreExecute(re "node<31:16>")
pcreExecute only returns a True/False result, while I would like to access the content of the capture groups. In this case it would be: list("31" "16")
The solution below works, but it looks ugly...
rel = pcreCompile("^.*<([0-9]+):.*$")
left_number=pcreReplace(rel "node<31:16>" "\\1" 1)
rer = pcreCompile("^.*:([0-9]+)>.*$")
right_number=pcreReplace(rer "node<31:16>" "\\1" 1)
    Andrew Beckett over 3 years ago +1
    You can do it with pcreSubstitute which is a bit more direct than pcreReplace. I also wrote a utility function around it here: https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill…
    You can do it with pcreSubstitute which is a bit more direct than pcreReplace. I also wrote a utility function around it here: https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/47374/get-a-list-of-the-matched-backreferences
