  3. After creating dockable window containing a form, how to...
  • Replies 9
  • Views 12127
After creating dockable window containing a form, how to locate and delete in order to recreate the dockable window and form
blankman
blankman over 3 years ago
I am trying to create a dockable window in layout window containing a form, however I am running into the issue after creating the window/form, that when the "x" top right of the dockable window is pressed, it doesn't actually close the window, but hides it. To be able to unhide the window after it is hidden, I need to re-create the window&form by again calling the procedure, however in order for this to work, I must first locate and delete the originally created dockable window and form. This is where I have the question. Does anyone know how to find and delete the original dockable window and form? Below is an outline of the code I am using to create the window.
Thanks and regards,
Brian.
After defining a form within a procedure: "dockForm()"
procedure(dockFormDisplay()
myForm1= dockForm()
myDockW=hiCreateDockWindow( ?appType "text" ?widgetType "form" ?title "Form" ?form myForm1)
hiDockWindow( ?window myDockW ?session hiGetCurrentWindow()->sessionWindow ?side 'left )
  • blankman
    Edit, to give more information: when I call the above code for the 1st time in a session, it loads the docked form fine, however when I recall the above code in a session I get the following errors in CIW:
    *WARNING* hiCreateAppForm: Could not delete already created form dockForm
    *WARNING* hiCreateDockWindow: formStruct@0x28a35d28 has been instantiated. Same form can not exist in more than one form or window.
    *Error* hiDockWindow: argument for keyword ?window should be a window type (type template = "wgsxg") - nil
    Thus I believe I need to locate and close both the form and docked window in order to create the docked window again.
  • blankman
    blankman over 3 years ago in reply to blankman
    Update: I have now managed to resolve the issue with the following code, this allows for the dockable window to be created, and then if the “x” is pressed top right of docked window, it will “re open” (re map) the docked window.
    However this brings 2 further issues…
    1: this only works on 1 layout window. When called from a second window after already being called from the first, it doesn’t work.
    2: also, when called from the 1st layout window, and that window is then closed: when then called in a second opened layout window, I get the following error message:
    *Error* hiMapWindow: Invalid window - window(invalid):649201536(destroyed)
    I believe I need to first check within the current session window if the docked form has been created, and depending on that, either 1: create it within that session window, or 2: map the docked window using hiMapWindow, to ensure anytime the function is called within that session window that the docked window appears. But the knack being it needing to check uniquely within each opened layout session window. Simple enough, but from a skill perspective does anyone know how to implement the correct coding/syntax etc?
    Also, for the hiDockWindow command, does anyone know how to get the dock window to dock to the north of other windows on that side of the screen? ie to the north of the layer palette, as opposed to the south (underneath)? It appears this can be done using the ?index parameter within hiDockWindow, however the correct value to use is not clear.
    Additionally, is it possible to set the height at which the docked window will be opened at once docked, ie how much vertical real estate the docked window will be given upon being docked?
    Finally, using the command hiUndockWindow to then un dock the window, is it possible to set the x/y dimensions and screen position that the window will be undocked to?
    Thanks in advance,
    Brian.
    procedure(TestForm()
       text1=hiCreateOutputStringField(
            ?name 'text1
            ?prompt "Test Form\n"
        myForm=hiCreateAppForm(
            ?name gensym('TestAppForm)
            ?formTitle "Test App Form"
            ?fields
            list(
                list(text1 19:0 56:25 56)
        myForm
    procedure(callForm()
                    when(boundp('myDockW)
                                    hiMapWindow(myDockW)
                    unless(boundp('myDockW)
                                    myForm1=TestForm()
                                    myDockW=hiCreateDockWindow( ?appType "text" ?widgetType "form" ?title "Test App Form Window" ?form myForm1)
                                    hiDockWindow( ?window myDockW ?session hiGetCurrentWindow()->sessionWindow ?side 'left ?index 0)
    hiSetBindKey("Layout" "Ctrl<key>#" "callForm()")
  • AurelBuche
    AurelBuche over 3 years ago
    Hi Brian,
    When you close a dockable window it actually unmaps it.
    (If you hover on the 'x' button, you should see a tooltip saying 'hide' and not 'close')
    To close the window instead of unmapping it, the simplest thing is to add a visibilityProc.
    procedure( my_app_create_form()
      "Create and return 'My App' form"
      hiCreateLayoutForm(
        gensym( 'my_app_form)
        "My App"
        hiCreateFormLayout( 'main_layout
          ?items list( hiCreateOutputStringField( ?name 'text1 ?prompt "Test Form\n"))
    procedure( my_app_close_dwin(dwin mapped)
      "Close DWIN if MAPPED is nil, this is meant to be used as `hiCreateDockWindow' ?visibilityProc"
      ;; `hiEnqueueCmd' has to be closed because it is not possible to close directly a window
      ;; inside the visibilityProc
      my_app.dwin = dwin
      unless( mapped hiEnqueueCmd( "hiCloseWindow(my_app.dwin)" ))
    procedure( my_app_create_dwin()
      "Create and return 'My App' dockable window"
      hiCreateDockWindow(
        ?appType        "text"
        ?widgetType     "form"
        ?title          "My App"
        ?form           my_app_create_form()
        ?visibilityProc 'my_app_close_dwin
    procedure( my_app_map_dwin()
      "Map 'My App' dockable window into the current session window"
      hiDockWindow(
        ?window  my_app_create_dwin()
        ?session hiGetSessionWindow( hiGetCurrentWindow())
        ?side    'left
    Also, if you allow me to give you some advice:
    1. You should use `hiCreateLayoutForm' and associated functions (they are way smarter than `hiCreateAppForm'):
    `hiCreateFormLayout', `hiCreateVerticalBoxLayout', `hiCreateHorizontalBoxLayout', ...
    2. You should give more explicit names to your functions, the names you use (testForm, callForm, ...)
    are not meaningful and quite confusing
    3. Be careful with global variables (even more if you are using generic names) you will encounter unexpected issues
    If you modify those variables in two different scripts, which is very probable with objects named myForm, myForm1,
    myDockW, ...
    If you need variables to be shared between your functions, a good solution is to give a generic name to your script
    and use the '.' operator
    my_app.form = hiCreateLayoutForm(...)
    my_app.dwin = hiCreateDockWindow(...)
    4. When you share your code, please avoid sending it piece by piece.
    It is quite complicated to ensure the behavior is the same if the whole script is different.
    Hope this helps,
    Aurélien
  • AurelBuche
    AurelBuche over 3 years ago in reply to AurelBuche
    If you want to display only one dockable window, you can modify the code like this :
      hiCreateLayoutForm(
        "My App"
    procedure( my_app_close_dwin()
      "Make sure my_app.dwin is closed"
      when( my_app.dwin
        my_app.dwin=nil
    procedure( my_app_close_dwin_cb(_dwin mapped)
      "`my_app_close_dwin' wrapper to close dockable window when unmapped,
    close my_app.dwin when MAPPED is nil.
     This is meant to be used as `hiCreateDockWindow' ?visibilityProc"
      ;; window inside the visibilityProc
      unless( mapped
        hiEnqueueCmd( "my_app_close_dwin()" )
      ;; Always store newly created dockable windows in global variable
      ;; Also make sure previously defined window is closed
      my_app_close_dwin()
        ?appType        "text"
        ?widgetType     "form"
        ?title          "My App"
        ?visibilityProc 'my_app_close_dwin_cb
      hiDockWindow(
        ?side    'left
  • blankman
    blankman over 3 years ago in reply to AurelBuche
    Thanks AurelBuche, this is very helpful. This allows me to create a dock window in one session window. However, when the dock window is then created in a second session window it deletes the dock window from the first session window. Is there a way to have multiple dock windows open at any one time; ie multiple session windows, and within each session window, the dock window?
    Also, when having created the dock window in a session window, and then that session window is closed, I get the following error message when trying to recreate the dock window in a newly opened session window. Is there a means to address this so as to allow for the dock window to be again created in the newly opened session window?
    *Error* hiCloseWindow: Invalid window - window(invalid):663445024(destroyed)
    Thanks again for your help. All most appreciated,
    Brian
  • AurelBuche
    AurelBuche over 3 years ago in reply to blankman
    Hi Brian,
    You can do that using several methods
    A simple one consists in storing the dockable window as a custom property of your window or session window
    Another one is done by creating a mapping table that will reference each dockable window using its associated window/session window
    Here is an example of the second solution:
      hiCreateLayoutForm(
        "My App"
    procedure( my_app_close_dwin(swin)
      "Make sure dockable window in SWIN is closed"
      when( my_app.dwins_table[swin]
        hiCloseWindow(my_app.dwins_table[swin])
        remove( swin my_app.dwins_table )
    procedure( my_app_close_dwin_cb(dwin mapped)
      ;; Find session window containing dwin
      let( ( (swin car( exists( swin my_app.dwins_table[?] my_app.dwins_table[swin]==dwin)))
        unless( mapped
          ;; As the following expression is called in a string, we have to fetch session
          ;; window number and retrieve the window object using `swindow'
          hiEnqueueCmd( lsprintf( "my_app_close_dwin(swindow(%d))" cadr(parseString(lsprintf("%L" swin)))))
    procedure( my_app_create_dwin(swin)
      ;; Always store newly created dockable windows in global table
      unless( tablep( my_app.dwins_table )
        my_app.dwins_table = makeTable('dwins nil)
      my_app.dwins_table[swin] = hiCreateDockWindow(
        ?appType        "text"
        ?widgetType     "form"
        ?title          "My App"
      let( ( (swin hiGetSessionWindow( hiGetCurrentWindow()))
        hiDockWindow(
          ?window  my_app_create_dwin(swin)
          ?session swin
          ?side    'left
    Cheers,
    Aurélien
  • blankman
    Thanks Aurélien, again very helpful and appreciated. Final question for now if you could also help with: is there a means that the dock window can be docked to the north of other windows that are already docked on that side of the screen? For instance, in my setup I have the Layer Palette docked to the left side of the screen, and I wish for the new dock window to dock to the north of the Layer Palette. Currently it docks to the south, ie at the end of the dock area, and could be easily missed. I have searched the hiDockWindow command, and it looks like ?index allows for this to be implemented, however, the value for which I have not been able to figure out in order to get it to dock to the north, or top, of the dock area. Thanks again, Brian.
    hiDockWindow(
          ?session swin
          ?side    'left
    ?index -1 )
  • AurelBuche
    Unfortunately my trials were not successful neither
    Maybe this feature is not working and a CCR should be filled
    Cheers
    Aurélien
  • blankman
    Thanks again Aurélien, appreciate it. Kind regards, Brian.
