  3. align instances to pins in lower hierarchy based on con...
  • Replies 8
  • Subscribers 152
  • Views 9840
align instances to pins in lower hierarchy based on connectivity
JRP29
JRP29 over 3 years ago
I am looking for a quick way to align instances or pcells like NODE_BREAKER/ METAL_RESISTOR to pins in lower hierarchy in layout based on connectivity.
For example, I have 100 pins say A2D<1:100> in a layout and in next hierarchy level those 100 pins are connecting to next level pins A2D_TOP<1:100> but with node_breaker/metal_resistor separating them. To align the top level pins to below level, first I need to align those 100 node_breaker/metal_resistor to the lower level pins.
Manually doing this is time consuming. Is there a way to align instances to pins in lower level?
  • JRP29
    JRP29 over 3 years ago in reply to AurelBuche +1
    Thanks Aurel. Now it works properly. But it completes with below error after placing them. (Less worried as everything is placed in exact place) *Error* dbTransformBBox: Invalid bBox - nil
  • AurelBuche
    AurelBuche over 3 years ago
    Hi, without more details it is quite hard to understand exactly what you want to do. (A screenshot is very welcome to illustrate what you mean)
    However, I modified a script I already developped to achieve the goal  I understood from your explanation.
    Here it is :
    (defun ab_auto_place_instances ( @key  (cv         (geGetEditCellView))
                                           (cell_name  "rmx"              )
                                           (horiz_just 'left              )
                                           (vert_just  'bottom            )
                                     @rest _args )
      "Browse CV incomplete nets, align each instance matching CELL_NAME to the first found pin
    in the incomplete net. HORIZ_JUST can be 'left, 'center or 'right. VERT_JUST can be 'bottom, 'center or 'top. "
    ;; Define functions used to align the pins (let ((get_x (caseq (concat (lowerCase horiz_just)) (left (lambda (box) (leftEdge box))) (right (lambda (box) (rightEdge box))) (center (lambda (box) (xCoord (centerBox box)))) (t (error "?horiz_just should be 'left, 'center or 'right")) )) (get_y (caseq (concat (lowerCase vert_just)) (bottom (lambda (box) (bottomEdge box))) (top (lambda (box) (topEdge box))) (center (lambda (box) (yCoord (centerBox box)))) (t (error "?vert_just should be 'bottom, 'center or 'top")) )) ) ;; Browse incomplete nets (foreach incomplete_net (lceGetIncompleteNets cv) ;; Try to find instance matching CELL_NAME ;; 'source' prefixed variables describe objects related to the instance matching CELL_NAME ;; 'target' prefixed variables describe objects related to the destination pin used to align (letseq ((conns incomplete_net->instTerms) (source_conn (car (exists conn conns (equal cell_name conn->inst->cellName)))) ) (when source_conn (letseq (;; Find source pin box (source_inst source_conn->inst) (source_pin_shape (car source_conn->term->pins)->fig) (source_pin_box (dbTransformBBox source_pin_shape->bBox source_inst->transform)) ;; Find target pin box (target_conn (car (remove source_conn conns))) (target_inst target_conn->inst) (target_pin_shape (car target_conn->term->pins)->fig) (target_pin_box (dbTransformBBox target_pin_shape->bBox target_inst->transform)) ;; Find the offset vector between source and target (x (funcall get_x target_pin_box)-(funcall get_x source_pin_box)) (y (funcall get_y target_pin_box)-(funcall get_y source_pin_box)) ) ;; Align source_inst on target_inst (dbMoveFig source_inst cv (list x:y "R0" 1.)) ));letseq ;when ));letseq ;foreach ));let ;def
    It should work out-of-the-box using :
    (ab_auto_place_instances ?cell_name "<resistor_cell_name>")
    Changing the horizontal and vertical justification might be required according to the positions of your target pins.
    Here is my example test case and the result :
    Hope this helps, don't hesitate to ask if you have any question
    Cheers,
    Aurélien
  • JRP29
    Hi Aurelien,
    Thanks for the Reply. The scenario is same as explained by your script . Attached schematic representation for the same for illustration.
    I have to align 230 METAL_RESISTORS to the pins A2D_ADC1<1:230> inside a hierarchy in layout.
    Your script is throwing error saying "undefined function - ccv" . The function
     (lceGetIncompleteNets (ccv)) is not defined. can you provide a fix for this?
  • AurelBuche
    AurelBuche over 3 years ago in reply to JRP29
    Oups, (ccv) is just an alias for (geGetEditCellView) I used it during my tests but it should not appear in my code (which I just edited)
    I replaced it with the variable cv and it should work
  • JRP29
  • AurelBuche
    My code is just an example and worked in my simple test case. It's nice if it seems to work properly but actually it lacks many checks and assertions.
    I don't know the look of your incomplete nets but the first thing to do in the script would be to check that target_conn and target_inst variables are non-nil.
    The following version should work without error :
                                           (cell_name  "rmx"              )
                                           (horiz_just 'left              )
                                     @rest _args )
          (when (and source_conn source_inst
    target_conn target_inst
    ) (letseq (;; Find source pin box (source_pin_shape (car source_conn->term->pins)->fig) (source_pin_box (dbTransformBBox source_pin_shape->bBox source_inst->transform)) ;; Find target pin box (target_pin_shape (car target_conn->term->pins)->fig) (target_pin_box (dbTransformBBox target_pin_shape->bBox target_inst->transform)) ;; Find the offset vector between source and target (x (funcall get_x target_pin_box)-(funcall get_x source_pin_box)) (y (funcall get_y target_pin_box)-(funcall get_y source_pin_box)) ) ;; Align source_inst on target_inst (dbMoveFig source_inst cv (list x:y "R0" 1.)) ));letseq ;when ));letseq ;foreach ))
  • JRP29
    Hi. Your code works properly. I  have one more requirement - Is there a way to align the instances to pins at same hierarchy and not to the pins at below hierarchy? Thanks in advance!
  • Mavrick
    Mavrick over 3 years ago in reply to AurelBuche
    Hi,Aurel
    I just used your code ,but it doesn't seem to work.Does the pin layer need to be specified? i used "pin" layer for both pin and it's text .
    This is how i do with your code :
    i load the code file in CIW, and the return value is t,then i type in CIW:
    (ab_auto_place_instances ?cell_name "<>")
    ,in the <> i replace the cell name i need
    and the ciw window returns some code in the following format:(db:.......... db:.......... db:........ db:......)
    there is only one layout window i opened,but my pins stay still in layout   : (
    feels
  • AurelBuche
    Hi JRP29,
    The current solution I provided you with should work with both?
    If I understand correctly, you want to skip the pins that are not in current hierarchy level?
    To do so you might just add a filter on target_conn & target_inst to make sure target_conn is in current level
    (I haven't tried though)
    Also please note that using incomplete nets is a simple but limited solution (If a pin [that should also be connected] is closer than the one you target, you might not get the result you expect)
    Cheers
    Aurélien
