  3. how to add net connectivity info or overwrite net connectivity...
  • Views 7260
how to add net connectivity info or overwrite net connectivity using skill ?
kiranbengaluru
kiranbengaluru over 3 years ago
Hi ,
Im using below cmd to overwrite net info . and its executing but its not reflecting in the layout. Please let me know any alternative way or reason its not overwriting the shape~>net.
net_name="vss"
net_db=dbMakeNet(cv_id net_name))
dbAddFigToNet(shape net_db)
  • AurelBuche
    AurelBuche over 3 years ago
    This is due to the sticky net property
    There you go:
    (defun set_shape_net (shape net)
      "Add NET connectivity to SHAPE"
      (letseq ((prop_name "lxStickyNet"                   )
               (prop      (dbGetPropByName shape prop_name))
        (if prop (setf prop->value "TRUE") (dbCreateProp shape prop_name "boolean" t))
        (dbAddFigToNet shape net)
