  3. How to generically wrap a function to be called in a loop...
  • Replies 12
  • Views 12611
How to generically wrap a function to be called in a loop with for a parametric sweep
ItsMichael
ItsMichael over 3 years ago
I would like to create a function which can wrap any function and execute it multiple times with a "sweep" of one of the arguments.
I guess I can do this with funcall() , but how can I parse the arguments in a generic way ?
Will that just involve string manipulation and some sort of evalstring() usage ?
To clarify what I want, let's say my wrapper function is called run_for_list:
run_for_list( plus 3 (1 2 3 4))
So basically I want loop through the plus() function for the list argument.
This is obviously just an example of the usage, my aim is to run a sweep of an argument for a calculator function and return a family of plots.
Any suggestion on how to implement such a thing ?
Thanks in advance,
Michael
    Andrew Beckett over 3 years ago in reply to ItsMichael +1
    Michael, How about this? defmacro (abSweepCalc (loopVar loopValues expression) ; the local variable has an underscore to try to avoid accidental ; capture with a variable in the expression (in…
  • ItsMichael
    ItsMichael over 2 years ago in reply to Andrew Beckett
    Thanks Andrew,
    I just noticed your reply.
    Even though I have a working solution I think I will rewrite it to use the macro, it's much more elegant.
    Just wondering about the apostrophes, could you briefly explain the use of the apostrophe before the let statement and inside the first argument of famCreateFamily ? is this related to the syntax of the macro definition ?
    also, is the first argument of the foreach loop empty ?
    I also find the mixing of commas and spaces to separate arguments confusing, do they serve the same purpose ?
    Andrew Beckett over 2 years ago in reply to ItsMichael
    The commas are not separators. There is an (undocumented) syntax in SKILL where commas can be used as an alternative separator to white space, but that's not what is going on here. What I'm using is the backquote operator (before the let) which is a macro that allows selective evaluation within a quoted list. If you use a normal quote (') rather than backquote (`) then everything inside the list is treated as unevaluated. If however you use backquote, then you can selectively evaluate things inside the list. The way it works is that anything preceded by a comma is evaluated, or if preceded by ,@ (not used in this case) then it's a list that is spliced in at that point.
    Put simply, this is a convenient shorthand for building complex lists with lots of symbol in - for example - I can build:
    `(a b (c d ,someVar) x y)
    rather more concisely than:
    liist('a 'b list('c 'd someVar) 'x 'y)
    In the case of macros it's particularly convenient because the resulting code structure looks like the code I'm trying to generate. Another way of looking at this is that with the surrounding backquote, everywhere that there's a comma-something expression, then the evaluated value of something is stuffed into the resulting code structure. Macros don't evaluate their arguments before they are called, and instead return a list which is the code to use instead - so can programmatically transform a set of arguments into some code which is used instead.
    The specific example I gave of using the macro ends up transforming into this code:
    let(((_family famCreateFamily('start 'double))
        foreach(start '(2e-08 4e-08 5e-08)
            famAddValue(_family start
                clip(VT("/OUTP") start 2e-07))
        _family
    Hope that helps!
