  3. How to generically wrap a function to be called in a loop...
  • Replies 12
  • Views 12610
How to generically wrap a function to be called in a loop with for a parametric sweep
ItsMichael
ItsMichael over 3 years ago
I would like to create a function which can wrap any function and execute it multiple times with a "sweep" of one of the arguments.
I guess I can do this with funcall() , but how can I parse the arguments in a generic way ?
Will that just involve string manipulation and some sort of evalstring() usage ?
To clarify what I want, let's say my wrapper function is called run_for_list:
run_for_list( plus 3 (1 2 3 4))
So basically I want loop through the plus() function for the list argument.
This is obviously just an example of the usage, my aim is to run a sweep of an argument for a calculator function and return a family of plots.
Any suggestion on how to implement such a thing ?
Thanks in advance,
Michael
    Andrew Beckett over 3 years ago in reply to ItsMichael +1
    Michael, How about this? defmacro (abSweepCalc (loopVar loopValues expression) ; the local variable has an underscore to try to avoid accidental ; capture with a variable in the expression (in…
  • AurelBuche
    AurelBuche over 3 years ago
    Hi Michael,
    I never used `famMap' so I can't really tell if it is the right solution or not for your case
    Anyway, you can call any function by its name using `funcall' or `apply'.
    They almost do the same job except in the way they receive the arguments :
    1. funcall takes them as if the function was called directly:
      (printf "%d %d" 12 27) ~ (funcall 'printf  "%d %d" 12 27)
    2. apply takes them as a list:
      (printf "%d %d" 12 27) ~ (apply 'printf '("%d %d" 12 27))
    For your example, you can do:
    procedure( sweepCalc(func_name parameters parameter_name_to_sweep start_value step_size stop_value)
      ;; Make sure FUNC_NAME is callable
      (assert (isCallable func_name) "Unable to call %A, it is not a valid function name" func_name)
      ;; Sweep over given range
      (for x start_value stop_value step_size
        (funcall func_name x)
    Your call will become
    sweepCalc('valueAt VT("signal") "n_xValue" 0u 1u 10u)
    Do not forget the quote " ' ", otherwise SKILL interpreter will complain that valueAt is an unbound variable
    You can construct functions name using `concat' but I advise you to avoid it as much as possible...
    (it becomes very hard to debug when you have to deduce built function names that are called in fancy ways)
    sweepCalc(concat( "value" 'At) ...)
    Also,you don't need to pass "n_xValue" as you can define the variable used in `for' directly
    procedure( sweepCalc(func_name parameters start_value step_size stop_value)
    sweepCalc(valueAt VT("signal") 0u 1u 10u)
    And you inverted the order of step_size and stop_value, it is quite confusing compared to the other SKILL calls you can make using those arguments (`for', `linRg', ...). You should stay consistent as much as possible
    Hope this helps
    Aurélien
  • ItsMichael
    ItsMichael over 3 years ago in reply to AurelBuche
    Thank you so much for the reply.
    My own research this morning lead me to funcall(), but from your example I think apply() is best suited if I get the input arguments as a list.
    I have just edited the question to be slightly more generic (right before reading your reply).
    I agree it's better to just use a list for the sweep which can be easily generated by linRg.
    For a generic implementation for such a sweep, I'm currently thinking about getting a parameter list.
    I could check which one of the parameters given is a list it self (which would mean that I would like to sweep that parameter)
    and then, according to it's position in the list, generate the function calls with apply.
    I'll post my solution here if it works.
    Michael
  • AurelBuche
    AurelBuche over 3 years ago in reply to ItsMichael
    Ok,
    I looked at your updated post
    In this case what you can do is Curry (Wikipedia - Currying) your function and then map it to your list
    run_for_list( 'plus 3 (1 2 3 4))
    procedure( run_for_list( fun val args)
      "Apply FUN with VAL to ARGS"
      assert( isCallable(fun) "Unable to call %A, it is not a valid function name" fun)
      mapcar( lambda( (x) funcall(fun val x)) args )
    ;; Is equivalent to
      foreach( x args
        funcall( fun val x)
  • ItsMichael
    ItsMichael over 3 years ago in reply to ItsMichael
    Ok, this is what I came up with, sorry for the formatting, for some reason the indentations were not copied [how did you put this cool looking block of code ?]
    procedure( sweepFunc(func_name @rest args)
    ; Make sure func_name is callable
    assert(isCallable(func_name) "Unable to call %A, it is not a valid function name" func_name)
    ; Find where the list in the args is
    list_idx = 0
    while(type(nth(list_idx args)) != type(list()) list_idx++)
    ; Iterate over the list's values
    sweepValues = nth(list_idx args)
    foreach( currentValue sweepValues
    ; substitute the list in the args by it's current value
    new_args = copy(args)
    setf_nthelem(currentValue list_idx+1 new_args)
    ; call the function with the arguments
    res = apply( func_name new_args)
    printf("%L\n" res)
    sweepFunc('plus 1 '(2 4 6 7) 3)
  • AurelBuche
    Unfortunately my previous answer was considered as SPAM due to a wikipedia link
    It might be released one day...
    Why do you assume the list argument (to sweep over) can be passed at any position?
    This is very messy and makes your code quite complicated
    It should be simpler to force its position (let's assume its the last value)
      foreach( x args
        funcall( fun val x)
    About my code snippets, I created an emacs-lisp script to extract my code as HTML using my colors
    In this forum when you create your reply you can use : Tools -> Source Code and insert HTML directly
  • AurelBuche
    If you really want your function to work wherever the list to sweep over is:
    it is cleaner to use `exists' to find it and then `remq' to remove it from the arguments
    (`remove' works also but in this case `remq' is more adapted)
      letseq( ( (sweepValues car( exists( val args listp(val) )))
                (otherArgs  remq( sweepValues args))
         printf("%L\n" apply( func_name currentValue otherArgs))
    Using `letseq' I define sweepValues and I can use it in otherArgs definition (this does not work with a classic `let')
    sweepValues contains the first list found in args
    otherArgs contains all values in args except sweepValues
    The final trick is that `apply' can contain any number of middle arguments that are added to the final one using `cons'
    apply( fun arg0 arg1 args)
    is equivalent to
    apply( fun (cons arg0 (cons arg1 args)))
  • ItsMichael
    My use case for this is to run a sweep on one of the custom or built-in calculator functions and display the results as a family.
    So for example if I would like to sweep the value of the clip() function, it takes two arguments so I would like to keep the option to sweep the start or the end of the clip.
    ie. clip(signal '(1u 2u 3u) 10u) or clip(signal 1u '(8u 9u 10u))
  • AurelBuche
    Ok, I get it but it is very tricky.
    Anyway your code should work but I am afraid it might become really confusing and hard to debug if you use it extensively.
    I did not find a clean and safe solution yet, maybe creating a macro...
  • ItsMichael
    Thanks for all the suggestions and inputs.
    This will rarely be used, it's mostly to used to sweep calculator functions.
    The current use-case is to sweep a linearity calculation function with different voltage ranges to analyze the dynamic range of the circuit.
    I didn't know about the listp(), was looking for a "isList" function but couldn't find. The naming convention here is not the most consistent.
    I will look into using letseq, exists and remq for finding the first list in the list.
    Thanks again.
    Best regards,
    Michael
    Michael,
    How about this?
    defmacro(abSweepCalc (loopVar loopValues expression)
      ; capture with a variable in the expression (in the absence of
      ; hygenic macros)
      `let(((_family famCreateFamily(',loopVar 'double)))
        foreach(,loopVar ,loopValues
          famAddValue(_family ,loopVar ,expression)
        _family
    You can then use:
    abSweepCalc(start '(20n 40n 50n) clip(VT("/OUTP") start 200n))
    In other words, you specify the loop variable, the list of values to iterate over and an expression where you use the loop variable somewhere in the expression.
    I used a macro (since that's the easiest way of having something code-like in the arguments without messing around with quotes, and avoids needing to use eval() etc.
