  3. Skill to Read Maestro Checks/Asserts Database
  • Views 1961
EvanD
EvanD over 3 years ago
I am looking for a way to read instances from Maestro Checks/Asserts database. I am able to open the database using the maeOpenViolationDb Skill command but am unsure of which commands will allow me to read this data.
My goal is to be able to dynamically read through some of the static voltage domain violations and determine if they are waivable through individual device properties. To do that I need to be able to access the instances reported failures are occurring on.
I appreciate the help!
- Evan
    Evan,
    This API seems to only be useful for programmatically setting or clearing waivers, and not to read the data. You should contact customer support as I don't think there's a way to do this with SKILL. You can however define custom SQL queries in the checks/asserts interface - but this may not be enough.
