  3. Power/ground/signal plot directly from layout
  • Views 1279
SSR
SSR over 3 years ago
I'm trying to do a power/ground/signal plot directly from layout. There are multiple approaches, and one readily available in Virtuoso is to do a markNet and save the net. But the drawback is, this takes really long and it runs in the foreground, also only one net plotting can be done at a time. Better method would be to run this on an oas db in the background. Someone got any solution to this in a SKILL that can be readily used?
Ram
