  3. I want to create via on two metal overlaps, and I need to...
  • Subscribers 153
  • Views 8471
I want to create via on two metal overlaps, and I need to pull back or delete the metal overhang or extensions to via center? Kindly help me, just started on coding.
CDB
CDB over 3 years ago
HI all,
I am able to generate vias on two metal overlaps using  " (viaGenerateViasFromShapes cv shapes via_opts) "
but I am not able to extend the metal overlaps which are extra, as in auto via you will be having metal extensions with drc clean.
basically I want to stretch the metal overhang on the vias.
  • psill00
    psill00 over 3 years ago +1
    Hello You might want to try the viaRecomputeViasAtPoint An example of some of the syntax I have used techId = techGetTechFile(cv) constrGrpId = cstFindConstraintGroupIn(techId "default") viaOpt = viaGetViaOptions…
  • psill00
    Hello
    viaOpt = viaGetViaOptions(constrGrpId)
    viaOpt~>automatic~>extendEnclosureBeyondOverlap = t
    viaOpt~>automatic~>printStatisticsReport = nil
    viaRecomputeViasAtPoint(cv xy viaOpt ?startLevel 0 ?stopLevel 32)
    Paul
  • yogeshjaiswalCAD
    yogeshjaiswalCAD over 2 years ago in reply to psill00
    thanks for sharing key idea, could you please share you code so that  i will be able to understand better , your support will be appreciated
  • yogeshjaiswalCAD
