  3. dbDeleteObject() : delete only specifc bBox
  • Views 7738
santvlsi
santvlsi over 3 years ago
Hello all,
I am trying to delete selected bBox/layer from layout and here is my approach:
cv=geGetEditCellView()
req_shapes=setof(get cv~>shapes get~>lpp ==list("M1" "drawing") || get~>lpp ==list("M2" "drawing"))
req_shapes~> bBox     ---> which shows the bBox of req_shapes
I will use dbDeleteObject() function to delete selected layer
But I am confused how to delete the specfic bBox  [ I tried foreach( delete req_shapes dbDeleteObject(delete))   --> this will delete all selected databases(i intended to delete only specfic bBox) ]
Please let me know the solution for above problem.
CS
    You could use a region query to find the shapes you want - for example:
    M1shapesInBox=dbShapeQuery(cv list("M1" "drawing") list(x1:y1 x2:y2) 0 0)
    where the list(x1:y1 x2:y2) defines the box for the query. You can only search for a single layer this way. Or you could use:
    shapesInBox=dbGetOverlaps(cv list(x1:y1 x2:y2)
    and then filter the result to look for just the lpps you want.
  • santvlsi
    santvlsi over 3 years ago in reply to Andrew Beckett
    Perfect.Thank you
