  3. hiAddFields: invalid field description in fieldList
  • Views 8101
mythverdic
mythverdic over 2 years ago
I am trying add two string fieds horizontally in a form:
hiAddFields(
form
list(
list(hiCreateStringField(
?name 'test1
?prompt "test1") 0:0 30:40)
?name 'test2
?prompt "test2") 60:0 30:40)
where variable "form" has already created by hiCreateAppForm() method, but code above encountered warnings:
*WARNING* hiAddFields: invalid field description in fieldList
*WARNING* Field adding ABANDONED
However, code below works fine if I delete the two-dimensional information:
hiAddFields(
form
list(
?name 'test1
?prompt "test1")
?name 'test2
?prompt "test2")
I have read SKILL reference, and it actually advises listFields could be as below:
list(
list( r_field1 l_XYlocation l_widthHeight [x_promptBoxWidthOrHeight])
list( r_field2 l_XYlocation l_widthHeight [x_promptBoxWidthOrHeight])
list( r_field3 l_XYlocation l_widthHeight [x_promptBoxWidthOrHeight])
list( r_field4 l_XYlocation l_widthHeight [x_promptBoxWidthOrHeight])
Please tell me what I got wrong! Thanks in advance!
    I don't get that error, but the issue is that you need to have specified the prompt width for these fields because they have prompts. It works for me... (although the fields are not going to be wide enough with the dimensions you gave).
    Far easier is to use layout forms rather than old "app" forms using coordinates, but if you are going to do that you have to provide sufficient information.
  • mythverdic
    mythverdic over 2 years ago in reply to Andrew Beckett
    Thanks for your reply,Andrew.
    Below is the code that would arise warnings:
    ;;myformtest.il
    include "listDev.il"
    ; Create string entry for the form.
    procedure( myformDefineFields()
    ; Create a button for the form.
    listbutton = hiCreateButton(
    ?name boolfldglb
    ?buttonText "list device"
    ?callback "listdev_cb(myformglb)"
    list( listbutton )
    ;Generate the form
    procedure( myformcreateform()
    if( !boundp('myformglb)|| (myformglb == nil)
    then
    myformglb = hiCreateAppForm(
    ?name'myformglb
    ?fields myformDefineFields()
    ?formTitle "My Form"
    ?buttonLayout'OKCancel
    myformglb
    ;Display the form
    procedure(myformdisplayform()
    myformcreateform() ;;; Creation and Display are separate
    hiDisplayForm(myformglb)
    The listDev.il is as below:
    ;;listDev.il
    procedure( listdev_cb(form)
    ;delete additional old fields
    hiDeleteFields(form cdr(form->fieldList))
    hiAddFields(
    form
    list(
    ?name'test1
    ?prompt "test1") 0:0 60:40)
    ?name'test2
    ?prompt "test2") 0:0 60:40)
    Andrew Beckett over 2 years ago in reply to mythverdic
    OK, the problem is that your main form has NOT been created as a 2D form (there were no coordinates in the initial field placement). So it's a 1D form - you cannot then add fields with coordinates to such a form (you can add fields, but they always will appear at the bottom. Secondly, the 2D descriptors for the string fields are incorrect (as I said before) because they are missing the prompt width (which is required since the field has a prompt). Thirdly, the coordinates in the example above would mean that the fields are on top of each other. Fourthly various things have gone wrong when pasting the code (missing spaces, missing quotation marks, missing parentheses).
    Anyway, here's fixed versions of the two files which will behave:
    ;;myformtest.il
        ?name 'boolfldglb
      list( list(listbutton 0:0 200:30))
    ;Generate the form
        then
    	?name 'myformglb
    	?buttonLayout 'OKCancel
        myformglb
    ;Display the form
    listDev.il:
      hiAddFields(
        form
        list(
    	?name 'test1
    	?prompt "test1") 0:30 200:30 80)
    	?name 'test2
    	?prompt "test2") 0:60 200:30 80)
  • mythverdic
    Thanks a lot for your patience sorry for my so  many mistakes. It really saves me a lot of debug time.
    By the way, do you have any suggestion on which document should I
    go for if I encounter  other warnings or errors. So far, my only
    reference is the built-in SKILL reference in cadence.
