  3. Find the overlapping shapes between three layers
  • Replies 12
  • Views 11747
Anmoljot
Anmoljot over 2 years ago
We have a requirement as shared below:
  • Finding the overlapping shapes between multiple layers
  • Updating an existing layer by adding the shapes found in the previous step.
Kindly refer to the below image for the further description of requirement shared below:
Figures 1, 2 and 3 show the shapes for Layer A, B and C respectively and the Outline layer shape.
The requirement is to do an equivalent of "AND" operation to get just the shapes that overlap between the three layers.
The second part is to add these shapes to the OUTLINE layer as shown in the figure 4.
The smaller shapes in the middle region of fig. 1, 2 and 3 are not overlapping and hence not appearing in the output figure 4.
Please help to provide Skill commands which can meet the requirement.
Kindly let me know if any further details are required.
Anmol
  • AurelBuche
    AurelBuche over 2 years ago +1
    Hi, You should definitely have a look at Cadence Advanced Boolean Engine [ABE] documentation This is meant to extract all shapes from a layer through a layout hierarchy and efficiently run boolean…
  • AurelBuche
    AurelBuche over 2 years ago in reply to Anmoljot +1
    You are missing the last functions I described in my previous answer : abeLayerToCellView, abeLayerToHilightSet and abeDone
    Andrew Beckett over 2 years ago in reply to Anmoljot +1
    Pass ?tiles nil to the abeLayerToCellView() function. The default is that it outputs the individual tiles otherwise.
  • Anmoljot
    Anmoljot over 2 years ago in reply to Andrew Beckett
    Hello Andrew,
    This is what the data looks like with fill:
    Anmol
    OK, so presumably there are small gaps between the regions you've drawn (otherwise it would have merged into a single polygon - feasible because the vertex count is not too high). I presume that there are also small gaps in the original (non-tiled) output of the abeLayer results too - and it's not clear why you think it should be able to end up with the result above (again, I can't see the detail from the pictures).
