  3. Find the overlapping shapes between three layers
  • Replies 12
  • Views 11746
Anmoljot
Anmoljot over 2 years ago
We have a requirement as shared below:
  • Finding the overlapping shapes between multiple layers
  • Updating an existing layer by adding the shapes found in the previous step.
Kindly refer to the below image for the further description of requirement shared below:
Figures 1, 2 and 3 show the shapes for Layer A, B and C respectively and the Outline layer shape.
The requirement is to do an equivalent of "AND" operation to get just the shapes that overlap between the three layers.
The second part is to add these shapes to the OUTLINE layer as shown in the figure 4.
The smaller shapes in the middle region of fig. 1, 2 and 3 are not overlapping and hence not appearing in the output figure 4.
Please help to provide Skill commands which can meet the requirement.
Kindly let me know if any further details are required.
Anmol
  • AurelBuche
    AurelBuche over 2 years ago +1
    Hi, You should definitely have a look at Cadence Advanced Boolean Engine [ABE] documentation This is meant to extract all shapes from a layer through a layout hierarchy and efficiently run boolean…
  • AurelBuche
    AurelBuche over 2 years ago in reply to Anmoljot +1
    You are missing the last functions I described in my previous answer : abeLayerToCellView, abeLayerToHilightSet and abeDone
    Andrew Beckett over 2 years ago in reply to Anmoljot +1
    Pass ?tiles nil to the abeLayerToCellView() function. The default is that it outputs the individual tiles otherwise.
  • Anmoljot
    Kindly note I have referred to the below case.
    Program for finding the bBox of the intersection (or AND operator) of two layers - Custom IC SKILL - Cadence Technology Forums - Cadence Community
    Referring to this, I tried the following ABE commands, but the output is not coming as expected.
    abeInit(cv)
    m0=abeLayerFromCellView("Metal1")
    m1=abeLayerFromCellView("Metal2")
    intersections=abeNewLayer()
    abeLayerAnd(m0 m1 intersections)
  • AurelBuche
    This is meant to extract all shapes from a layer through a layout hierarchy and efficiently run boolean operations on it
    The functions you need are:
    abeInit, abeLayerFromCellview, abeLayerAnd, abeLayerToCellView, abeLayerToHilightSet and abeDone
    Cheers,
    Aurélien
  • AurelBuche
  • Anmoljot
    Anmoljot over 2 years ago in reply to AurelBuche
    Hello Aurélien,
    Thank you for your response!
    I have used abeLayerToCellView function as well, but in the output layer I am seeing that the AND operation is breaking the overlapping shapes into smaller rectangles. Is that behavior expected? I will try to share an illustration as well.
    Also, will check out the abeLayerToHilightSet function.
    Anmol
  • Anmoljot
    Anmoljot over 2 years ago in reply to Anmoljot
    I think the post below might possibly explain why the shapes are splitting into multiple smaller rectangles.
    Number of Points for a shape cannot more than 4000 - Custom IC SKILL - Cadence Technology Forums - Cadence Community
    Although not sure why the resulting polygons from AND for above layers could have >4000 points.
  • Anmoljot
    I am wondering if there are any commands in skill that can help to select shapes of a layer having width greater than a certain value.
    Thinking of this as a workaround to filter out the smaller shapes (that are non-overlapping) and then I would be left with the bigger shapes only.
    Kindly suggest if there is any such command.
    Anmol
    Well, it doesn't "select" them, but the standard trick to filter small shapes out is to undersize them (e.g. using abeLayerSize with a negative size) and then oversize them again with the same size. If you use half the minimum width you want for the undersizing and oversizing, then they'll be filtered.
  • Anmoljot
    Anmoljot over 2 years ago in reply to Andrew Beckett
    I got to try this now, as I got stuck with some other higher priority work.
    By passing ?tiles nil to the abeLayerToCellView() function, I am getting the following output:
    Output without ?tiles nil is as shown below:
    The required output is something like this:
    Could you please suggest if there is something else that I can try to get this required output?
    Any help her would be really appreciated.
    Anmol
    Hi Anmol,
    Without seeing the data, I can't comment on why the results are the way they are (I'm assuming there are small gaps in the regions where some of the lines are shown). I'm also not sure why it should produce a shape like you've suggested (given that there's no fill in the layers you're drawing it's impossible to see where the solid areas are).
    I suggest you contact customer support so somebody can see your actual data. There's not going to be a magic switch to produce what you want - but maybe some additional processing can get there (as I said, I can't guess what the data actually looks like from your pictures).
