  3. creating PINs from selected nets in schematic
  • Views 11090
naresh9005
naresh9005 over 2 years ago
Hello, I'm new to skill coding and need to wire one skill code to generate pins in the schematic based on selected nets.
procedure(CreatePinFromselNet()
ss = geGetSelectedSet()
netname = ""
netname1 = ""
foreach(sss ss
netname1 = sss~>net~>name
netname = strcat(netname "\n" netname1)
printf("You can make the following pins in the schmeatic by clicking wherever you want %c" netname)
schHiCreatePin( ?terminalName netname ?direction "input" ?usage "schematic" )
netname = nil
hiiToggleEnterForm(schCreatePinForm)
This script fails when we select bus nets like net<0:5>, net1:10>, etc.
please help us, how to create pins from the selected bus -nets as well ?
Regards
Naresh
  • AurelBuche
    AurelBuche over 2 years ago in reply to naresh9005 +1
    Hi Naresh, I strongly advise you to follow some SKILL training to understand what is going on in Andrew's script, you can find many articles in Cadence support This one is a good starting point: Where…
    Naresh,
    Not sure why you are using "\n" to concatenate all the names together on the strcat() line. If you change it to " " (a space) then it will work fine.
    Or you could simply replace the foreach loop with:
    netname=buildString(ss~>net~>name)
    which is simpler still (of course, there's no error checking that everything selected has a net name - you could solve that by adding a setof to filter. I also added some local variable declarations and also enqueued the toggling of the enter form:
      let((ss netname)
        netname = buildString(setof(nn ss~>net~>name stringp(nn)))
        printf("You can make the following pins in the schematic by clicking wherever you want %s" netname)
        hiEnqueueCmd("hiToggleEnterForm(schCreatePinForm)")
  • naresh9005
    naresh9005 over 2 years ago in reply to Andrew Beckett
    Thank you Andrew ...
  • naresh9005
    Thank you for your response. I can now generate pins form the selected bus nets.
    while creating this pin , How can I add prifix or sufix to each pin ?
    To add the prifix, I'm replacing stringp(nn) with strcat("prix" nn) in the above script, but it's not working.
    could you please help how can i do this ?
    Regards
    Naresh
  • AurelBuche
    Hi Naresh,
    This one is a good starting point: Where do I look for SKILL example codes, tutorials, and trainings?
    You should at least lookup and understand the following basic functions :
    list
    quote ‘
    cons
    car
    cdr
    nth
    progn
    prog1
    let
    if
    when
    unless
    cond
    case
    foreach
    setof
    exists
    forall
    concat
    strcat
    To do so, in Virtuoso main window (CIW) you go to the banner menu 'Tools' -> 'SKILL API Finder' and you can obtain the documentation for each function
    You can now see that `setof` is a function to filter a list using a predicate and that `stringp` is a predicate to check that the provided object is a string
    By doing :
    Andrew is creating a concatenated string containing all valid names from ss~>net~>name
    You cannot just replace `stringp` by `strcat` because those two functions are not doing the same thing at all!
    What you can do is : building the list of prefixed names, and then concatenate them.
    ;; Filter empty names
    netname = setof(nn ss~>net~>name stringp(nn))
    ;; Remove duplicated names (you might want to do that)
    netname = removeListDuplicates(netname)
    ;; Prefix names
    netname =  foreach( mapcar nn netname strcat("prix" nn) )
    ;; Build final string
    netname = buildString( netname )
    Note that this is not the more efficient way to do it (you browse your list several times) however it is quite clear to do it step by step and also you would have to select a huge amount of objects before having performances issues
    Hope this helps,
    Aurélien
