  3. Stream in oasis--With Multiple cores
  • Subscribers 150
  • Views 2595
mattab
mattab over 2 years ago
I want to stream-in oasis with multiple cores so that the  stream-in happens fast.Normal stream-in is taking huge time
Please help with any command for this
thanks in advance !!!
    This is covered in the documentation - see the section Multithreading in XOasis In in Design Data Translators Reference -- Design Translation Using XOasis Translator - Design Translation During XOasis In
    Note that if you use OASIS in to virtual memory, then it's turned off, and I think the default is 2 cores (there's an env var that allows you to increase it). It doesn't not always give you a huge gain because it may be limited by the reading of the file or other factors.
    If you are still facing performance issues, I suggest you contact customer support (submit a support case after logging in).
