  3. Using nested scripts
  • Replies 14
  • Views 13512
ArbLouis
ArbLouis over 2 years ago
Hi. I'm trying to create a set of vias using a SKILL file.
Issue 1: Instead of replicating the same piece of code several times, I'd like to use, within the main script, a call to a function (which hopefully I can store as an external file on a custom location and reuse in other projects).
Issue 2: Furthermore, I'd like to pass to this function some parameters, e.g. a position.
This is an example of main script in which I've highlighted where I'd like to call the external function creating a stack of vias (this part of code is not written, I've just used here the script file name viacreator.il).
I hope someone could help.
pcDefinePCell(list(ddGetObj("TestExternalFunction") "testPCELL_SKILL" "layout") nil
let((pcMember pcStretchGroup stretchOffsetX stretchOffsetY pcLib
pcMaster pcInst pcTerm pcPin pcPinName
pcNet pcTermNet pcNetName pcTermNetName pcMosaicInst
pcParameters pcParamProp pcStep pcStepX pcStepY
pcRepeat pcRepeatX pcRepeatY pcIndexX pcIndexY
pcLayer pcPurpose pcLabelText pcLabelHeight pcPropText
pcParamText pcCoords pcPathWidth pcPolygonMargin
(pcLib = (pcCellView~>lib))
(pcParameters = ((pcCellView~>parameters)~>value))
(pcLayer = 187)
(pcPurpose = "drawing")
(pcInst = dbCreateRect(pcCellView
list(pcLayer pcPurpose)
list((0.0:-14.5)
(25.0:-7.5)
(pcLayer = 19)
list((23.355:-14.46)
(24.945:14.4)
; Call to an external function located, for instance, in the folder /EDA/SKILL
viacreator ( list((23.355:-14.46) )
Thanks for your help!
    Andrew Beckett over 2 years ago in reply to ArbLouis +1
    The libInit.il can't just be anywhere you want. It has to be in the library directory as that's the only place it will be auto-loaded from. Also, the paths in any load() call either need to be full paths…
  • ArbLouis
    ArbLouis over 2 years ago in reply to Andrew Beckett
    I've been able to create a SKILL code using an external function (called MY_viacreator) which generates a PCELL layout that can be instantiated and works well. Very cool!
    When I create a cell using a PCELL instance it works fine but, as I close and open Virtuoso, the PCELL shows the text "".
    I can notice that the log reports this error: pcell Eval Failed.
    *WARNING* (DB-270001): Pcell evaluation for MY_CELLS/myPCELL_TEST/layout has the following error(s):
    *WARNING* (DB-270002): ("eval" 0 t nil ("*Error* eval: undefined function" MY_viacreator))
    *WARNING* (DB-270003): Error kept in "errorDesc" property of the label "pcellEvalFailed" on layer/purpose "marker/error" in the submaster.
    This error appears only when I use an external function and after I restart Virtuoso. No errors appear when I do not use an external function. I hope you could help me.
    Presumably the file containing the function definition is not being loaded. Did you definitely load the file from within the libInit.il file in the library containing the PCell? (I’m sure something must have been done incorrectly because this mechanism works well and is widely used)
  • ArbLouis
    Thanks Andrew. I fixed it. .
    MY_cell (folder)
        - MY_functions (folder)
       - libInit.il
    The libInit.il file contains a single line:
    load("./MY_cell/MY_functions/MY_viacreator.il")
    In the main Skill code (which is located in a folder different from the MY_cell one) I load the libInit.il. Now it works. thanks a lot!
    Also, the paths in any load() call either need to be full paths, or if relative they are relative to the SKILL path and not relative to the file from which they are loaded). You can use this approach in the library libInit.il :
    let((pathToMe dirPat dirPath)
      pathToMe=get_filename(piport)
      dirPat=pcreCompile("/[^/]*$")
      dirPath=pcreReplace(dirPat pathToMe "" 1)
      load(lsprintf("%s/fileToLoad.il" dirPath))
    Ah, I now see you edited the post to say you fixed it (I really must get used to reading the posts rather than just the email notification...). Anyway, maybe the above will be useful.
