  3. Using nested scripts
  • Replies 14
  • Views 13510
ArbLouis
ArbLouis over 2 years ago
Hi. I'm trying to create a set of vias using a SKILL file.
Issue 1: Instead of replicating the same piece of code several times, I'd like to use, within the main script, a call to a function (which hopefully I can store as an external file on a custom location and reuse in other projects).
Issue 2: Furthermore, I'd like to pass to this function some parameters, e.g. a position.
This is an example of main script in which I've highlighted where I'd like to call the external function creating a stack of vias (this part of code is not written, I've just used here the script file name viacreator.il).
I hope someone could help.
pcDefinePCell(list(ddGetObj("TestExternalFunction") "testPCELL_SKILL" "layout") nil
let((pcMember pcStretchGroup stretchOffsetX stretchOffsetY pcLib
pcMaster pcInst pcTerm pcPin pcPinName
pcNet pcTermNet pcNetName pcTermNetName pcMosaicInst
pcParameters pcParamProp pcStep pcStepX pcStepY
pcRepeat pcRepeatX pcRepeatY pcIndexX pcIndexY
pcLayer pcPurpose pcLabelText pcLabelHeight pcPropText
pcParamText pcCoords pcPathWidth pcPolygonMargin
(pcLib = (pcCellView~>lib))
(pcParameters = ((pcCellView~>parameters)~>value))
(pcLayer = 187)
(pcPurpose = "drawing")
(pcInst = dbCreateRect(pcCellView
list(pcLayer pcPurpose)
list((0.0:-14.5)
(25.0:-7.5)
(pcLayer = 19)
list((23.355:-14.46)
(24.945:14.4)
; Call to an external function located, for instance, in the folder /EDA/SKILL
viacreator ( list((23.355:-14.46) )
Thanks for your help!
    Andrew Beckett over 2 years ago in reply to ArbLouis +1
    The libInit.il can't just be anywhere you want. It has to be in the library directory as that's the only place it will be auto-loaded from. Also, the paths in any load() call either need to be full paths…
    In the file viacreator.il you'd need to define a function - typically done using procedure() (there are other ways, but this is probably the most natural).
    procedure(viacreator(cv bBox)
      dbCreateRect(cv list("Via1" "drawing") bBox)
    There's no requirement for the function name to match the file name, you can have multiple function definitions in each file, and it's a good idea to give them a unique prefix to avoid clashing with anybody else's functions - viacreator is not terribly unique, for example. So something like "CCFviacreator" (CCF being Cadence Community Forum; we recommend an uppercase prefix to avoid clashing with anything from Cadence).
    Then you'd call it:
    viacreator(pcCellView list(23.355:-14.46 24.945:14.4))
    (you had a space after the function name in your call which isn't legal - also the list() structure wouldn't work because you have matching duplicate parentheses which will confuse matters).
    For more detail, I suggest you read the SKILL Language User Guide or take one of the free online SKILL training classes at http://support.cadence.com (in the Learning section in the middle at the top).
  • ArbLouis
    ArbLouis over 2 years ago in reply to Andrew Beckett
    Thanks a lot for the reply. I would be grateful if you can provide me some info about the file location? How should I handle it?
    The file location can be wherever you want, but you probably want to add a libInit.il file within the library directory that contains your PCell - this file is a SKILL file and should include a load("/path/to/your/code.il") to load it. That will then automatically load any functions used within your PCell at the time the library is first accessed. If you don't do that, nothing will auto-load your SKILL code.
  • ArbLouis
    I did not perfectly understood your suggestions.
    In my case I'm running Skill from the  folder A="/home/user/cadence/ST/XXX"
    Inside this folder I have a subfolder SKILL and a sub-subfolder where I'd like to collect my functions. This will be B="/home/user/cadence/ST/XXX/Skill/MY_functions/"
    What you say is that I should create a file named libInit.il  in my folder A. This file should have as many lines as my functions are. Each line should look like this:
    load("/home/user/cadence/ST/XXX/Skill/MY_functions//MY_viacreator.il")
    I tested this and it does not work. I still get the underfined function error.
    As an alternative I was trying to change the SKILL path but this does not work either.
    if( not(car(getSkillPath)="/home/user/cadence/ST/XXX/Skill/MY_functions/")
    setSkillPath(cons("/home/user/cadence/ST/XXX/Skill/MY_functions/" getSkillPath()))
    ); endif
  • ArbLouis
    Hi Andew, I've solved by starting the file with the string: load("path/to/file.il")
    My question now is: do you have any suggestion to load all the files of a folder instead of doing this operation one by one? Thanks.
    You could do this:
    foreach(file sort(pcreMatchList("\\.il.*$" getDirFiles("/some/directory")) 'alphalessp)
      loadi(file)
    The pattern matching is just to look for anything that has a suffix of .il something (so copes with .ile, ils, ilse suffices too), and the sort is to ensure they are loaded in a well-defined order (if it matters).
    I think this post got held up in moderation and based on your later dated reply you've solved it since?
    BTW, the code:
    ); endif
    is not correct. getSkillPath() is a function, and your code will treat it as a variable (plus it would only work if it wasn't the first entry in the list. It would be better to do:
    unless(member("/home/user/cadence/ST/XXX/Skill/MY_functions" getSkillPath())
      setSkillPath(cons("/home/user/cadence/ST/XXX/Skill/MY_functions" getSkillPath()))
  • AurelBuche
    AurelBuche over 2 years ago in reply to Andrew Beckett
    I believe your pattern matching lacks a dot '.'
    foreach(file sort(pcreMatchList("\\.il.?$" getDirFiles("/some/directory")) 'alphalessp)
      loadi(file)
    This should work with all the file extensions you mentioned
    Cheers
    Aurélien
    Andrew Beckett over 2 years ago in reply to AurelBuche
    Hi Aurélien,
    Good catch (the perils of not testing what you just typed). Yours won't catch the ".ilse" suffix, so I edited my original reply to have the dot before the star (so I've hidden the evidence of it ever being wrong!)
  • ArbLouis
    Thank you so much, Andrew. Your suggestions have been very helpful, especially for someone like me who is just starting out. I appreciate your compassion.
