  3. Attaching property to a property
  • Subscribers 150
  • Views 6463
RK56
RK56 over 2 years ago
The subject could be misleading as I dont know the correct terminologies. I have attached some values to CI window to use as global variables.
hiGetCIWindw()~>layer_M1 = (list("M1" "drawing") list("M1" "pin"))
hiGetCIWindw()~>layer_M2 = (list("M2" "drawing") list("M2" "pin"))
Now I want to group them into another level of depth like
hiGetCIWindw()~>layerUtils~>layer_M1 = (list("M1" "drawing") list("M1" "pin"))
hiGetCIWindw()~>layerUtils~>layer_M2 = (list("M2" "drawing") list("M2" "pin"))
How to do this? Also what is the correct way to ask this question?
Ram
    Hi Ram,
    Given that properties on window objects are just a reference to a SKILL structure, the simplest approach is to make layerUtils a hash table. Hash tables can be indexed using -> or ~> where the key is a symbol. The alternative is to make it a disembodied property list or a structure (defstruct); the disembodied property list would require you to use -> rather than ~> and the defstruct requires you to pre-declare the structure. Overall I think using a hash table is the simplest. For example (fixing the typos in your code too):
    hiGetCIWindow()~>layerUtils=makeTable('layerUtils nil)
    hiGetCIWindow()~>layerUtils~>layer_M1 = list(list("M1" "drawing") list("M1" "pin"))
    hiGetCIWindow()~>layerUtils~>layer_M2 = list(list("M2" "drawing") list("M2" "pin"))
    You then retrieve the value using hiGetCIWindow()~>layerUtils~>layer_M1 .
