  3. Keep guis or menus from closing
  • Views 8389
psill00
psill00 over 2 years ago
When I am working in layout or schematic I hit the escape button and the form is active and disappears or closes
I there a way to keep the menus/guis/forms from closing
I used these functions to create the forms, hiCreateLayoutForm or hiCreateAppForm
Paul
  • psill00
    I think I found a solution menu/guis/forms closing by using dockable forms
    Now I have a new problem.
    When I switch between tabs the form closes and I get warning when added the dock form to switched tab.
    *WARNING* hiGetWinConfig: duplicate dock assistant name found: miniMojo
    Any solution to fixing this problem
    my script I use to dock the form
    procedure(dockGuiToWindow(form formTxt formSide)
    let( (dock
    (swin hiGetSessionWindow(hiGetCurrentWindow()))
    dock=hiCreateDockWindow(
    ?appType "Dock Gui"
    ?widgetType "form"
    ?handle gensym("dockGui")
    ?form form
    ?title formTxt
    hiDockWindow(
    ?window dock
    ?session swin
    ?side concat(formSide)
    )); end of dockGuiToWindow
    Paul
  • psill00
    psill00 over 2 years ago in reply to psill00
    Me again
    Is there a equivalent hiGetCurrentForm() for dockable form/guis?
    Paul
    Andrew Beckett over 2 years ago in reply to psill00
    No. Escape always calls hiFormCancel.
    Yes, you should use hiSetWinObjName to ensure that there is a unique name for each dock window. See the code below:
    procedure(createForm()
      hiCreateAppForm(
        ?name gensym('MyForm)
        ?formTitle "The form"
        ?fields
          list(
            list(
              hiCreateStringField(
                ?name 'string
                ?prompt "string"
                ?callback lambda((field scope) printf("New value in field %L scope %L\n" field scope))
              0:0 300:30 100
      let( (dock
          ?appType "Dock Gui"
          ?widgetType "form"
          ?form form
          ?title formTxt
        ; ensure object name is unique for each dock window
        hiSetWinObjName(dock get_string(dock->hiHandle))
        hiDockWindow(
          ?window dock
          ?session swin
    No, because forms in dock windows are never the current form. However, if you use a function object callback (see the lambda in the string field above), the scope variable contains the specific form that the field is contained within. Perhaps that does what you want?
  • psill00
    psill00 over 2 years ago in reply to Andrew Beckett
    Hello
    I dont know if I need to create another post about the docking gui issue ( great info and greatly appreciated )
    The docking is working as I want but when I add another tab to the cell window the docking gui disappears.
    Is there a way to keep the docked gui when I add a tab or something to live with
    Paul
