  3. creating via
  • Views 7111
creating via
ChPavan
ChPavan over 2 years ago
hi i am using the code
tf=techGetTechFile(cvId)
viaDef=techFindViaDefByName(tf "M3_M2")
dbCreateVia(cvId viaDef 10:20 "R0") ; could also pass parameterList
but it is showing the error
*** Error in routine dbCreateVia:
Message: *Error* dbCreateVia: argument #1 should be a database object (type template = "ddltg") at line 25 of file "/home/nav/test1/code.il" - ?cvId
Entering new debug toplevel due to error:
can anyone solve this please
  • ChPavan
    sorry its argument #2 in the error message
  • AurelBuche
    AurelBuche over 2 years ago
    Hi please paste the full code test case and valid error because this is impossible to debug
    It seems the value of one of your variables is the symbol ?cvId
    But as you shared only a snippet of your test case I cannot tell you why this occurred
    I assume cvId is wrongly defined in your code, maybe try:
    cvId = (geGetEditCellView)
