  3. How to use schHiCreateWireStubs() in skill procedure?
  • Views 7877
qc123
qc123 over 2 years ago
I am trying to use  schHiCreateWireStubs() after instancing a symbol the schematic.
procedure(CreateInstanceStubs(libName cellName viewName offset)
let( (cv ip instSymbol newInt)
;; Will create a schematic view
cv=dbOpenCellViewByType(libName cellName viewName "schematic" "a")
instSymbol=dbOpenCellViewByType("library" "cell" "symbol" nil)
newInt=dbCreateInst(cv dutSymbol "device_inst" list(0 0) "R0" 1)
;..... more code after stubs are placed
I get error.
It seem schHiCreateWireStubs() only works if I have the schematic window open and works the same as Create > Wire Stubs and Names. I tried putting (dbReopen cv "r") but still get error. How can I "open" the schematic to place stubs. I will be adding more to the schematic in the code after.
Thanks for any help or insight
  • qc123
    So i guess there is no easy function like dbCreateWireStubs() or use geGetCellViewWindow(). But here is  How to add wire stub and a net name to the given floating instance terminal on multiple instances? that can be modified to work for any other.
    Andrew Beckett over 2 years ago in reply to qc123
    There's no public non-Hi (i.e. not expecting a user interface) API to do this (there probably should be, but there isn't), and so something along the lines of the article you found is probably the best starting point. I've written similar code myself in the past.
