  3. How to ensure that only one hiRegTimer process is running...
  • Views 8771
How to ensure that only one hiRegTimer process is running at any one time
blankman
blankman over 2 years ago
Hi All,
I see that when using hiRegTimer, calling it multiple times initiates it each time, so that there then are multiple hiRegTimer processes running in parallel.
I wish to use hiRegTimer in a way, that if it is called more than once, each time it is called kills the previous hiRegTimer process, so that only one hiRegTimer process is running at any one time. Is it possible to do this?
B
    B,
    You can't - hiRegTimer doesn't offer the ability to do this. However, you might want to consider using my CCStimer package that provides a more convenient interface and introduces the idea of having job IDs, being able to specify repeating jobs, and also provides a mechanism to terminate scheduled jobs given their job ID. It uses hiRegTimer underneath, but also allows you to schedule closures and function objects which can be useful too.
    Of course, you still have to use this wisely because everything is still single-threaded and so you don't want to be scheduling code that takes a lot of resources on a frequent basis.
    Here's my article: How to schedule a repeating function with a timer in SKILL
  • blankman
    blankman over 2 years ago in reply to Andrew Beckett
    Thanks Andrew, adding use-case below in case you might know of an easier means of implementing?
    A procedure that allows the user to toggle off the visibility of “Boundary”, “FigGroup” and “Custom Placement Area” objects to allow the user more visual clarity when viewing larger/top level layouts. After 5 minutes the visibility of these objects automatically switch back on again.
    I had been using hiRegTimer within this procedure to do this (as below), however resulting the aforementioned issue when called multiple times. Is there another means by which such a delay in turning back on the Object vis could be achieved? Reading the code you provided it sounds like it can freeze the interface if ran for any considerable length of time, if I understand correctly?
    hiRegTimer("AutoOnImproveVis()" 3000)
  • AurelBuche
    AurelBuche over 2 years ago in reply to blankman
    Can't you use a global variable to set a timestamp?
    Everytime your procedure is called, you check the previous timestamp, deduce what to do accordingly
    Then you reset the timestamp using current time
    The associated functions you might want to check: getCurrentTime compareTime timeToString
    Hope this helps,
    Aurélien
  • blankman
    blankman over 2 years ago in reply to AurelBuche
    Thanks Aurélien, appreciated, B
    Andrew Beckett over 2 years ago in reply to blankman
    This sounds (to me) a very odd use model (and personally I'd think that could be pretty annoying that it suddenly changes back 5 minutes later when you're in the middle of doing something, or have wandered over to a colleague to bring them over to show them what you've seen - and it changed while you were away!). However, if you really want to do this - then using hiRegTimer or my CCStimer makes sense - not sure there's any other real way.
    You could easily use the CCStimer for this - keeping track of a global handle when this is scheduled and then if called again you could terminate the current "job" and reschedule again (updating the global handle to the latest registered timer).
    The "freeze the interface for any considerable length of time" bit is just saying that you should be cautious if you are running something very frequently and the callback you're calling takes a long time to execute (that doesn't seem likely to be the case from what you've described).
  • blankman
    Thanks very much Andrew, appreciated, I will take a closer look at CCStimer (have not had a lot of time on my hands lately). Kind regards, B
