  3. sklint function
  • Views 8285
sklint function
Curtisma
Curtisma over 2 years ago
Hello:
I'm trying to write a SKILL++ wrapper function to lint multiple SKILL++ files with the same settings.
However I can't get it to work.  The sklint() function appears to contain nlambda functions or some other feature that is not compatible with SKILL++.
Can someone confirm that sklint is just not compatible with SKILL++?
At some point I received the following warning:
*WARNING* (sklint): calling NLambda from Scheme code - sklint(?file funcall((Path->Cat) (lint_settings->testsDir) "data_types/Path.ils") ?outputFile funcall((Path->Cat) (lint_settings->outputDir) "lint_report_Path.txt") ?prefixes (lint_settings->prefixes))
*WARNING* (sklint): calling NLambda from Scheme code - sklint(?file funcall((Path->Cat) (lint_settings->testsDir) "data_types/test_Path.ils") ?outputFile funcall((Path->Cat) (lint_settings->outputDir) "lint_report_test_Path.txt") ?prefixes (lint_settings->prefixes))
Here's my latest try to create a SKILL++ wrapper around sklint.  I am trying to return a Dpl that I can use to call the RunLint() function.  However, I receive the following error.
Error:
lint_settings=VrtImport->Test->Fixtures->lint_settings()
(nil RunLint funobj@0x27d8a070 outputDir "/prj/ids_dev/work_libs/mayberc/skill/virtue/test"
prefixes (Vrt VrtImport) testsDir "/prj/ids_dev/work_libs/mayberc/skill/virtue/tests"
lint_settings->RunLint("../virtue/Str.ils")
*** Error in routine eval:
Message: *Error* eval: unbound variable - file
Entering new debug toplevel due to error:
Code:
procedure(lint_settings()
"Test"
let(((outputDir simplifyFilename(Path->Cat(dir_path "../test")))
(prefixes '(Vrt VrtImport))
createDirHier(Path->Cat(outputDir "data_types"))
procedure(RunLint(relativeFilePath)
"Run lint on a file relative to the tests directory"
let(((file Path->Cat(dir_path relativeFilePath))
(outputFile
Path->Cat(outputDir strcat(
"lint_report_"
Path->RemoveExtension(Path->FileName(relativeFilePath))
".txt"))
sklint(
?file file
?outputFile outputFile
?prefixes prefixes
list(nil
'RunLint RunLint
'outputDir outputDir
'prefixes prefixes
'testsDir dir_path
    Unfortunately sklint() is one of the relatively small number of nlambda functions (usually defined with nprocedure) left. These don't evaluate their arguments up-front and instead selectively evaluate the arguments within the function (I'm not sure there's a terribly good reason for sklint to be implemented this way, and even if there was there is a better way of doing this nowadays). Because of the evaluation within the function, these don't understand SKILL++ lexical environments.
    The good news is that you can workaround this by changing your sklint() call to:
    funcall(sklint
      ?file file
      ?prefixes prefixes
    The funcall will evaluate all the arguments up front lexically, and then call the actual function.This shouldn't then give the warning and I think should work as you wish (I didn't try it with your code but with something simpler in the interests of time).
  • Curtisma
    Curtisma over 2 years ago in reply to Andrew Beckett
    Ok, I'll try that.  Thanks Andrew!
  • Curtisma
    Curtisma over 2 years ago in reply to Curtisma
    I'll submit a ticket to fix the sklint to make it compatible directly with SKILL++ by removing the nlambda functions.  This wasted too much debug time.
  • AurelBuche
    AurelBuche over 2 years ago in reply to Curtisma
    Also do not expect wonderful results while using the Linter on SKILL++
    It was meant to be used on SKILL and struggles with many SKILL++ behaviors such as local functions.
    Also a little tip about unused function arguments :
    I don't believe this is documented but if you prefix functions arguments that you are not using with  underscores "_".
    You get an info instead of a warning message
    This can be useful for instance with callbacks
    (hiCreateButton ?name 'close_button ?buttonText "Close" ?callback (lambda (_button form) (hiFormCancel form)))
    Cheers,
    Aurélien
    Andrew Beckett over 2 years ago in reply to AurelBuche
    Hi Aurélien,
    It's actually much better than it used to be, which is quite remarkable given that it was designed a very long time ago before SKILL++ was even considered.
    BTW, the use of the underscore to prefix an unused argument is now documented in the SKILL IDE documentation; I asked for this to be done relatively recently when I discovered that it wasn't documented (I think it was implemented in IC6.1.8/ICADVM20.1 ISR29). I also filed CCR 2756155 to request that SKILL Lint flags any used arguments that begin with underscore (that hasn't been implemented).
    Curtis - I found the reason why sklint is a nprocedure. It's related to an incompatible change made over 25 years ago, so I don't think there's a particularly good reason for this to remain! There are still a reasonable number of nlambda functions that exist, but luckily most of them are not typically those that you want to call from code (I rarely hit the problem and write a lot of SKILL++ code).
