  3. Bind Key Query - Ctrl+Shift+0
  • Views 1876
Naveen002
Naveen002 over 2 years ago
@All_CAD,
I tried pressing "Shift+Ctrl+0" bind key combination in the bind key editor window. But the editor is not picking up any of the bindkey  statements.
While pressing this key combination, some calibre related function is being called. But there's no such function in the editor when checked.
What could be the reason behind it?
Also, any leads for adding this key combination?
Naveen Prasad
    Naveen,
    If I enter a new bindkey and press Shift+Ctrl+0 then I get the encoding:
    Ctrl<Key>)
    (the close parenthesis is what I get when use shift-0 on my keyboard). I don't know what you mean by "But the editor is not picking up any of the bindkey statements"? My guess is that there's already a bindkey defined for the combination.
    This is probably simplest to handle via customer support - that way you can share your screen with the application engineer and it would be easier to understand what is going wrong.
  • Naveen002
    Naveen002 over 2 years ago in reply to Andrew Beckett
    Andrew,
    Thanks for your quick reply!
    I'll confirm it once and get in touch with the support.
    -Naveen Prasad
