  3. Configuring Failed while installing IC231 on RHEL 8
  • Views 7726
sugeekusc
sugeekusc over 2 years ago
I am trying to install IC231 on RHEL 8 using installscape, however configuring keeps failing. Is there a command to manually do that part of the setup or is it ok to work with Virtuoso without the configuring completeted?
    By failing, what do you mean? What actually happens?
    You can run the configuration manually by running:
    sh /path/to/IC231/installData/IC231_lnx86/batch_configure.sh
    If that fails too, please show what happens when you do this.
  • sugeekusc
    sugeekusc over 2 years ago in reply to Andrew Beckett
    Thanks for the reply. I missed checking this space. Will these steps and get back right away.
