  3. Skill code to change Metal width
  • Replies 7
  • Views 10855
ManjunathYalameli
ManjunathYalameli over 2 years ago
Hi All,
I am trying to write a skill code to change the metal width bindkey. without opening its query form.
Here is my skill code
hiSetBindKey("Layout" "Ctrl<key>q" "change_metal_width()")
procedure(change_metal_width()
selected=geGetSelSet()
hiFocusToCIW( )
float_num=enterNumber()
selected~>width=float_num
This code works perfectly but I need to focus into CIW then I enter number the it changes width, If I comment hiFocusCIW() then run the script, view get stuck. Then I press ESC it comes back to normal without changing metal width. Please let me know what other commands I can use it.
Thank you in advance.
  • p94todorov
    p94todorov over 2 years ago
    I just tried your code and it works just fine after pressing Enter instead of ESC in the CIW.
    It brings back the window it was invoked from on focus and the instance is updated.
    Petar
  • ManjunathYalameli
    ManjunathYalameli over 2 years ago in reply to p94todorov
    Hi Petar,
    Thanks for the reply,  Here I don't want to bring CIW in between the code running.
    regards
    Manju
  • AurelBuche
    AurelBuche over 2 years ago in reply to ManjunathYalameli
    Hi Manju,
    There might be different approaches to achieve what you want
    I remembered this thread about bindkeys triggered using a succession of characters : How to create two or three key strokes bindkeys
    You might use something similar to type the numbers without having to focus to the CIW
    Another solution would be to make a little form pop-up with just a number string and press 'enter' or 'esc' to apply or cancel the form (I can provide you with a little example if you need it)
    Cheers
    Aurélien
  • RicardoGV1
    RicardoGV1 over 2 years ago
    Hi Manju,
    I answered my version on Aurel response about strokes bindkeys but I think the reply is waiting for aproval by an admin to be shown on the forum.
    But meanwhile, here is another approach I use, which can increase width with the mouse wheel
    Just uncomment bindkeys at the end and write your techGrid on the first lines instead of the GetTechGrid()
    R.Gómez
    ;; Change width:        ;;
    ;; This skill changes the width of the wires and vias depending on the                ;;
    ;; Technology Grid spacing                                                            ;;
    ;; AUTOR: Ricardo        ;;
    /*THIS IS THE INFORMATION TEMPLATE FOR ALL THE SCRIPTS
        Comments:
            1-Example
            2-Example2
                +More info
        Use:
          1.- select wire or via and use ctrl+shift+mousewheel to expand, also its variations ctr+mousewheel to expand diferent directions
        Features:
        Ideas:
        ToDo:
        Errors:
        FutureFixData:
        Dependences:
        CurrentlyWorking:
        DoneInCurrentCommit:
    procedure(CCSChangeWidth2(increment  @optional (XY "both")(Selection geGetSelSet()))
      let((incrementWire incrementVia tk pwi rw rw1 ln lp hs hp win RoutingList ViasList LR UD rw2 rw3 ln2 lp2 hs2 hp2 win2 via ratio ratio1)
        ;multiplied by increment to get direction (increment or decrement)
        incrementWire=_IncrementMult*increment*GetTechGrid()*2;;this cannot be the min grid
        incrementVia=_IncrementMult*increment*GetTechGrid()
        win=hiGetCurrentWindow()
        ; delete hilight set if already exists in case increment/decrement
        ; is done before timer has kicked in
        pwDeleteHilight(win)
        tk=geGetEditCellView()
        ;Filtering objs
        ViasList = setof(x Selection x~>objType == "stdVia");filtering to only vias
        RoutingList = setof(x Selection or(x->objType=="path" x->objType=="pathSeg"))
        ;increasing sizes
        when(RoutingList != nil
            pwi=car(RoutingList)
            rw=pwi~>width+incrementWire
            ;println(rw)
            pwi~>width=rw
            rw1=artMakeStringPrec15(rw);artMakeString is having troubles with floats
            ;println(rw1)
            ln=pwi~>layerName
            lp=pwi~>layerPurpose
            hs=geCreateHilightSet(geGetEditCellView() list(ln lp) nil)
            hs~>enable=t
            ; store the hilight set as a property on the window to
            ; retrieve later for deletion.
            win~>pwCommonHS=hs
            hp=hiGetPoint(win)
            geAddHilightLabel(hs hp rw1 "centerCenter" "R0" "stick" rw nil)
            hiRegTimer(lsprintf("pwDeleteHilight(window(%d))" win->windowNum) 5)
        when(ViasList != nil
            via=car(ViasList)
            LR=car(via->layer1Enc)
            UD=cadr(via->layer1Enc)
            case(XY
                ("both"
                    foreach(_via ViasList
                        _via->layer1Enc=list(LR+incrementVia UD+incrementVia)
                        _via->layer2Enc=list(LR+incrementVia UD+incrementVia)
                ("x"
                        _via->layer1Enc=list(LR+incrementVia UD)
                        _via->layer2Enc=list(LR+incrementVia UD)
                ("y"
                        _via->layer1Enc=list(LR UD+incrementVia)
                        _via->layer2Enc=list(LR UD+incrementVia)
            ;println(rw)
            ;pwi2~>width=rw
            ;println(ChangeWidthMode)
            rw2=artMakeStringPrec15(car(via->layer1Enc));artMakeString is having troubles with floats
            rw3=artMakeStringPrec15(cadr(via->layer1Enc));artMakeString is having troubles with floats
            ;println(rw1)
            ;ln2=pwi~>layerName
            ;lp2=pwi~>layerPurpose
            hs2=geCreateHilightSet(geGetEditCellView() list("text" "drawing") nil)
            hs2~>enable=t
            win~>pwCommonHS=hs2
            hp2=hiGetPoint(win)
            ratio=car(via->layer1Enc)
            ratio1=cadr(via->layer1Enc)
            geAddHilightLabel(hs2 list( ((car(hp2)-0.9)+car(hp2)*ratio/32) cadr(hp2))                               rw2 "centerCenter" "R0" "stick" ratio*2 nil)
            geAddHilightLabel(hs2 list( car(hp2)                        ((cadr(hp2)+0.1)+cadr(hp2)*ratio1/32))      rw3 "centerCenter" "R0" "stick" ratio1*2 nil)
    ; retrieve hilight set from the window, and delete if valid
    procedure(pwDeleteHilight(@optional (win hiGetCurrentWindow()))
      when(geIsValidHilightSet(win->pwCommonHS)
        geDeleteHilightSet(win->pwCommonHS)
    ChangeWidthMode="Left"
    procedure(ChangeMode()
        if(Mode=="Left"
            Mode="Right"
            Mode="Left"
    _IncrementMult=1
    procedure(ChangeIncrement()
    println("entro")
        if(_IncrementMult==1
            _IncrementMult=5
            _IncrementMult=1
    ;hiSetBindKey("Layout" "Shift <Key>/" "ChangeMode()") ; ChangeMode
    hiSetBindKey("Layout" "<Key>KP_Divide" "ChangeIncrement()") ; ChangeIncrement
    /*On Merged Bindkeys
    hiSetBindKey("Layout" "Shift Ctrl<Btn4Down>" "CCSChangeWidth2(0.005 \"both\")") ; Mouse scroll wheel up
    hiSetBindKey("Layout" "Shift Ctrl<Btn5Down>" "CCSChangeWidth2(-0.005 \"both\")") ; Mouse scroll wheel down
    hiSetBindKey("Layout" "Ctrl<Btn4Down>" "CCSChangeWidth2(0.005 \"x\")") ; Mouse scroll wheel up
    hiSetBindKey("Layout" "Ctrl<Btn5Down>" "CCSChangeWidth2(-0.005 \"x\")") ; Mouse scroll wheel down
    hiSetBindKey("Layout" "Shift<Btn4Down>" "CCSChangeWidth2(0.005 \"y\")") ; Mouse scroll wheel up
    hiSetBindKey("Layout" "Shift<Btn5Down>" "CCSChangeWidth2(-0.005 \"y\")") ; Mouse scroll wheel down
  • RicardoGV1
    RicardoGV1 over 2 years ago in reply to AurelBuche
    Hi Aurel,
    I'm trying to reply another version of Andrew's code, do you know if there is any character limit or something?
    I'm getting this text, but I don't have external links that can be causing that.
    R.Gómez
    Andrew Beckett over 2 years ago in reply to RicardoGV1
    I'm not sure which of "Andrew's code" you're referring to (ah, I assume it's the code in this old thread How to create two or three key strokes bindkeys). The reason you can't post it is because it uses the function "substring". For some bizarre reason, code containing this function gives the error you shared; I've had this before and it's been followed up by our IT team and I think reported to the forum software vendor. The code was probably posted in the previous forum system or an older version.
    If you get this error, it hasn't gone into moderation or because it thinks it's spam - it's just a strange bug in the forums...
  • RicardoGV1
    RicardoGV1 over 2 years ago in reply to Andrew Beckett
    Yes, that code.  This can save previous bindkeys and when pressing esq it retrieves them after using the code.
    Thanks for that information, so please Manju, if you use it, substitute al st by substring.
    R.Gómez
      ;called on initial setup to setup everything
            procedure(InitCustomStrokes()
                /********************* STROKES GODConsole **************************************/
                    ;println("entr")
                    ;loadi("CustomStrokes.ils")  ; para abrir GodConsole
                    loadi("/eda/homes/us11/rgomez/Documents/Skills/Prueba/skill/to_be_approved/Skills/CustomStrokes.ils")
                    ;CustomStrokes->initBindKeys("Layout")
                    CustomStrokes->set("Layout" "fit" "hiZoomAbsoluteScale(hiGetCurrentWindow() 0.9)")
                        ("COPY" "leHiCopy()")
                        ("CHOP" "leHiChop()")
                        ("DEL"  "leHiDelete()")
                        ("UNDO" "hiUndo()")
                        ("REDO" "hiRedo()")
                        ("NCube" "CubeUnload()")
                        ("deselectWireM1" "deselect(\"METAL1\")")
                        ("deselectWireM2" "deselect(\"METAL2\")")
                        ("deselectWireM3" "deselect(\"METAL3\")")
                /********************* END STROKES GODConsole **********************************/
            ;called when want to use the strokes (bind key this fn to start using script)
        /* CustomStrokes.ils
        toDo:
        -set a timer to clear inputs afer a while of not entering
        -keys to set input or finish (as enter or start of function)
        -delete seqBindKey by app - DONE
        -delete caracters - DONE
        -make this list available for unloadBindKeys CSlistBk, in order to have again the latest bindkeys
        -make that when caracters as ctrl, shift, escape, alt or some of those, wait until finish those words to enter
        -make that when
        Design:
        -when loading this script a predefined script will be loaded.
        -using esq take the user to the first layer which have no skill
        -then the user should select a skill to load writing it
        -also can press esq to unload this script and load custom bindkeys
        todo:
        -make this script works with shift/ctrl/alt  (this can be done by having an special caracter to start listen for  shift/ctrl/alt  buttons)
        bugs:
        extraInfo:
        Character(s)            SKILL Symbol Name(s)
        a, b, …, z              a, b, …, z
        A, B, …, Z              A, B, …, Z
        ?, _                    ?, _
        0, 1, …, 9              \0, \1, …, \9
        ^A, ^B, …, ^Z, …        \001, \002, …, \032, …
        (octal codes 001-037)   (in octal)
        <space>                 \<space> (backslash followed by a space)
        DEL                     \177
        *hiGetBindKeyPrefixList() ->show the existent applications
        CustomStrokes->initBindKeys("Layout")   use this to initialize
        Author     A.D.Beckett
        Group      Custom IC (UK), Cadence Design Systems Ltd.
        Language   SKILL++ (keep the .ils suffix on this file)
        Date       Oct 22, 2009
        Modified   July 10, 2022
        By          Ricardo Gómez
        A package to support sequence bindkeys. This means you can define multi-key
        bindkeys. So for example, you can define a bindkey "chop" - you type the four
        characters c, h, o, and then p - and this then triggers the bindkey.
        The sequence is displayed as a banner label so you can see the current
        sequence. Escape is normally used to reset the sequence.
        Note this is really a proof-of-concept - it is not fully formed, and may
        need some enhancement.
        ; Initialize the a-z, A-Z, and 0-9 bindkeys to be entry keys
        ; and escape to be a reset key for Layout application
        ;CustomStrokes->initBindKeys("Schematics")
        *hiGetBindKeyPrefixList() --->> to get every application existent
        ; give warning if any key sequence defined which obscures another
        ; for example, "ed" obscures "edit"
        CustomStrokes->option(?checkObscured t)
        ; Define some key sequences ;;;;;;;;;REMEMBER THAT EACH STROKE SET IS ADDED TO THE LIST, DOES NOT REPLACE PREV LIST
            ("UNDO" "hiUndo()")
            ("REDO" "hiRedo()")
        ; Retrieve bindkeys:
        CustomStrokes->get("Layout") => returns all the keys
        CustomStrokes->get("Layout" "chop") => "leHiChop()"
        ; If you want to define your own bindkeys (rather than using initBindKeys)
        ; then you'll need to use these:
        CustomStrokes->enter("X") ; enters an X in the sequence
        CustomStrokes->reset()    ; resets the sequence
        Limitations:
        Doesn't have the concept of "Enter Function" bindkeys which are
        different during enter functions. Could do, but needs some thought
        as to a sensible use model.
        SCCS Info: @(#) CustomStrokes.ils 10/22/09.13:44:45 1.1
        CSlistBk=list()
        importSkillVar(CustomStrokes CSlistBk);make the  CCSeqBindKey workspace to be global
        CustomStrokes=let(
            ((bindkeys makeTable('bindkeys nil)) obscuredCheck)
            *                     initBindKeys(appType)                      *
            * EXPORTED function to initialize the bindkeys a-z, A-Z and 0-9, *
            *  as well as Escape, to work with the sequence bindkey system.  *
            defun(initBindKeys (appType)
                let((appRoot)
                    appRoot=hiGetBindKeyInheritRoot(appType)
                    ;println(CSlistBk)
                    ;to make sure the bk's aren't already set
                    if(hiGetBindKey("Layout" "<Key>a")=="CustomStrokes->enter(\"a\")" then
                        FormError("Custom Strokes already loaded")
                    else
                        CSlistBk=hiGetBindKeys("Layout");saving last bindkeys to restore it later
                        when(appRoot
                            ; Define bindkeys for a-z, A-Z and 0-9
                            for(ascii charToInt('a) charToInt('z)
                                /*Saving bindkeys for screen key show*/
                                ;lastBK=(hiGetBindKey "Layout" "Shift<Key>T");save last bindkey
                                ;lastBK=hiGetBindKeys("Layout"); de aquí tengo que ir iterando para agregarlas
                                ;hiRegTimer("yhwDeleteLabel(yhwText)" 10); timer to do fn
                                /*Overwriting bindkeys*/
                                hiSetBindKey(appRoot
                                    strcat("<Key>" intToChar(ascii))
                                    sprintf(nil "CustomStrokes->enter(\"%s\")" ;//  \"%s\" es para concatenar el caracter en el argumento
                                        intToChar(ascii))
                                    strcat("Shift<Key>" intToChar(ascii))
                                        upperCase(intToChar(ascii)))
                            );for
                            for(ascii charToInt('\0) charToInt('\9)
                                    sprintf(nil "CustomStrokes->enter(\"%s\")" intToChar(ascii))
                            );for
                            hiSetBindKey(appRoot "<Key>Delete" "CustomStrokes->reset()")
                            hiSetBindKey(appRoot "<Key>BackSpace" "CustomStrokes->del()")
                            ;hiSetBindKey(appRoot "<Key>|" "CustomStrokes->del()")
                            Command=sprintf(nil "CustomStrokes->unloadBindKeys(\"%s\")" appRoot)
                            hiSetBindKey(appRoot "<Key>Escape"  Command)
                        );when appRoot
                );let
            );defun initBindKeys
            *                              enter(char)                              *
            *   EXPORTED Function to enter a character in the sequence. If there    *
            *     is a sequence bindkey registered for that sequence, reset and     *
            *       then execute the bindkey definition - otherwise continue        *
            * collecting the characters in the sequence (and display in the banner) *
            defun(enter (char)
                let((win appType appRoot bindkeyTab defn sequence)
                    when(win
                        sequence=strcat(win~>abSequence || "" char)
                        win~>abSequence=sequence
                    appType=win && hiGetAppType(win)
                    when(appType
                    when(appRoot
                        ; Look up the bindkey definition. If found, then
                        ; reset the sequence and evaluate it, otherwise just
                        ; append the current sequence.
                        bindkeyTab=bindkeys[appRoot]
                        defn=bindkeyTab && bindkeyTab[sequence]
                        if(stringp(defn) then ;stringp checa que haya algún string dentro de la cadena, igual hay listp y numberp
                            reset()
                            errsetstring(defn t)
                        else
                            if(st(sequence, 1,5)=="Seq: " then ;check if the seq: is in the string to erase it
                                sequence=st(sequence, 6,strlen(sequence))
                            hiChangeBannerLabel(
                                win
                                strcat("Seq: " sequence)
                                0
                        ) ; if bindkey found
                    ) ; when appRoot
                ) ; let
            ) ; defun enter
            *                           reset()                            *
            *       EXPORTED function to reset the current sequence        *
            defun(reset ()
                hiGetCurrentWindow()~>abSequence=""
                    "Seq: "
                    0
            ) ; defun reset
            *                           del()                              *
            *       EXPORTED function to delete last caracter              *
            defun(del ()
                let((win appType appRoot bindkeyTab defn sequence sequenceTemp)
                    when(win
                        ;sequence=strcat(win~>abSequence);|| "" char) ;;aquí concatena
                        sequence=win~>abSequence
                    when(appType
                    when(appRoot
                            reset()
                        else
                            if(sequence!=nil && strlen(sequence)>0   then ;;check if the string is empty, if empty does not delete
                                ;println("z")
                                println(sequence)
                                println(sequence)
                                    ;sequence=strcat("Seq: " st(sequence, 1,strlen(sequence)-1))
                                    sequence=st(sequence, 1,strlen(sequence)-1)
                                    ;sequenceTemp
                                        win
                                        sequence;Banner Label, pero aquí se borra uno en el banner
                                        0;x_labelPosition
                                    win~>abSequence=sequence ; para restablecer la secuencia
                                println(sequence)
                    ) ; when appRoot
                ) ; let
            ) ; defun del
            (defun MyUnique (lst)
                (let ((seen (makeTable 'seen nil)))
                    (setof elem lst
                    (unless (arrayref seen elem)
                        (setarray seen elem t)
            *                    check(bindkeyTab key)                     *
            *  INTERNAL function to check that a new key sequence is not   *
            *    obscured by another, or does not obscure another. Only    *
            *      checked if option(?checkObscured t) has been used.      *
            defun(check (bindkeyTab key)
                let((len subKeyName)
                    when(obscuredCheck && stringp(bindkeyTab[key])
                        len=strlen(key)
                        ; Look for any existing key sequences which the new key is
                        ; the beginning part of
                        foreach(keyName bindkeyTab
                            when(key!=keyName && zerop(strncmp(key keyName len)) &&
                                stringp(bindkeyTab[keyName])
                                warn("Definition for sequence %s will obscure sequence %s\n"
                                    key keyName)
                            ) ; when
                        ) ; foreach
                        ; Look for any key sequences which are shorter than the new key
                        for(sub 1 sub1(len)
                            subKeyName=st(key 1 sub)
                            when(stringp(bindkeyTab[subKeyName])
                                    subKeyName key)
                            ) ; when
                        ) ; for
                ) ;let
            ) ; defun
            *                   set(appType key [defn])                    *
            *  EXPORTED function to set one or more sequence bindkeys for  *
            *                        an application                        *
            defun(set (appType key @optional defn "tg") ;@optional makes that some argument have a default value, and can be not be setted on the argument, if not default value, nil is given
                let((appRoot bindkeyTab)
                    when(appRoot
                        unless(bindkeyTab
                            bindkeyTab=makeTable('appBindkeys nil)
                            bindkeys[appRoot]=bindkeyTab
                        ; Handle list of definitions, and individual definitions
                        if(listp(key) then
                            foreach(keyDefn key
                                if(listp(keyDefn) && length(keyDefn==2) then
                                    bindkeyTab[car(keyDefn)]=cadr(keyDefn)
                                    check(bindkeyTab car(keyDefn))
                                else
                                    warn("Key definition %L is invalid\n" keyDefn)
                        else
                            bindkeyTab[key]=defn
                        t
                    ) ; when appRoot
                ) ; let
            ) ; defun set
            *                        get(appType [key])                        *
            * EXPORTED function to get one or all sequence bindkey definitions *
            defun(get (appType @optional key "tg")
                    when(appType
                        ; If the key argument provided, just return the definition
                        ; otherwise return an assoc list of the whole lot
                        if(key then
                            bindkeyTab && bindkeyTab[key]
                        else if(!bindkeyTab then ;si no tiene data
                                    printf(nil "No data")
                    else
                        tableToList(bindkeyTab)
                ;printf(nil "No data")
                ;sprintf(nil "data is: %s" bindkeyTab)
                    ) ; when appType
                ) ; let
            ) ; defun get
            *                        deleteFrom(appType [key])                 *
            * EXPORTED function to delete one or all sequence                  *
            * bindkey definitions                                              *
            ;algo me falta aquí para que funcione bien al inicializarlo
            defun(deleteFrom (appType @optional key "tg")
                    when(appType
                ;sprintf(nil "entro");no imprimir porque hace returns
                        ;bindkeys[appRoot]=nil ;creo que no puedo hacer nil todo
                        bindkeys[appRoot]=makeTable('bindkeys nil)
                    ) ; when appType
                ) ; let
            ) ; defun deleteFrom
            *                        unloadBindKeys(appType [key])             *
            *        *geRestoreWinView()
            defun(unloadBindKeys (appType @optional key "tg")
                    when(appType
                        ;hiSetBindKeys( "Layout" tableToList(CSlistBk)) ;restore bindkeys
                        ;hiSetBindKeys( "Layout" listBK)
                        ;hiSetBindKeys( "Layout" 'hiGetBindKeys("Layout"))
                        ;[this is not going to be the final solution, just temporal as is not overriding every bindkey or deleting it]
                        ;load("/eda/common/tools/cadence/ic/6.1.8.220/tools.lnx86/dfII/samples/local/leBindKeys.il")
                        ;también cambiar este load al nuevo
                        /*********************************PROBAR PROBAR PROBAR******************/
                        ;borrar load de arriba
                        ;;creo que lo que faltaba al usar lastBK era iterarlo
                        ;foreach(bindKeyElement lastBK
                        ;   hiSetBindKey(bindKeyElement); si bindkeyElement no funciona, va a hacer falta separarlo por strings
                        /********************************* END PROBAR PROBAR PROBAR*************/
                        hiSetBindKeys(appRoot CSlistBk)
                    ) ; when appType
                ) ; let
            ) ; defun unloadBindKeys
            *                  option(@key checkObscured)                  *
            *       EXPORTED function to set any options. Currently        *
            *                     just ?checkObscured.                     *
            defun(option (@key checkObscured)
                obscuredCheck=checkObscured
            ; DPL containing all the package functions available from outside
            `(nil
                initBindKeys ,initBindKeys
                enter ,enter
                reset ,reset
                set ,set
                get ,get
                option ,option
                deleteFrom ,deleteFrom
                unloadBindKeys ,unloadBindKeys
                del ,del
    ) ; let
