  3. hiInsertMenuItem Error When Adding Custom Menu to CIW with...
  • Views 8385
hiInsertMenuItem Error When Adding Custom Menu to CIW with .cdsinit
sts
sts over 2 years ago
When I loading below code with SKILL IDE it adds a custom menu to CIW window and doesn't give any error for IC23.1-64b.ISR3.27. However, for again same Virtuoso version if I load the code at .cdsinit it still adds the menu to CIW but also gives below error at CIW which I have no idea.
*Error* hiInsertMenuItem: argument #1 should be a defstruct (type template = "rgg") - nil
Then, I changed Virtuoso version to 6.1.8-64b-500.27 and loading the code with both IDE and .cdsinit worked properly without any error.
;;; creating menu items for the slider menu
trA_MenuItem = hiCreateMenuItem(
   ?name  'trA_MenuItem
   ?itemText "A"
   ?callback "println('A)" ;;; prints A in the CIW
trB_MenuItem = hiCreateMenuItem(
   ?name 'trB_MenuItem
   ?itemText "B"
   ?callback "println('B)" ;;; prints B in the CIW
trC_MenuItem = hiCreateMenuItem(
   ?name 'trC_MenuItem
   ?itemText "C"
   ?callback "println('C)" ;;; prints C in the CIW
;;; building the slider menu
hiCreatePulldownMenu(
   'trSubMenu
   list( ; the list of menu items in the slider menu
      trA_MenuItem
      trB_MenuItem
      trC_MenuItem
;;; creating the first menu item for the pulldown menu
trSliderMenuItem = hiCreateSliderMenuItem(
   ?name 'trSliderMenuItem
   ?itemText "Print"
   ?subMenu trSubMenu
;;; creating the second menu item for the pulldown menu
trMenuItemResize = hiCreateMenuItem(
   ?name 'trMenuItemResize
   ?itemText "Resize"
   ?callback "hiResizeWindow( window(1) list(0:0 500:500))"
;;; creating the Example Menu pulldown menu
   'trPulldownMenu
   "Example Menu"
   list( trSliderMenuItem trMenuItemResize )
;;; inserting the pulldown menu in the CIW
hiInsertBannerMenu( window(1) trPulldownMenu 0 )
Thanks in advance,
Sedat
  • AurelBuche
    AurelBuche over 2 years ago
    Hi
    This kind of errors might occurs when the graphical environment is not fully loaded yet
    you should queue your final call using hiEnqueueCmd to make sure everything is properly setup before inserting your menu
    cheers
    Aurelien
    Andrew Beckett over 2 years ago in reply to AurelBuche
    Actually, adding menus in the .cdsinit should be fine; the need to use hiEnqueueCmd (as Aurélien suggested) is something you need to do if you are popping up forms or dialog boxes. Menus should be fine (you just have to call ciwMenuInit() first).
    Anyway, the problem here is caused by a change in IC23.1 related to some code for Virtuoso RF - there's an assumption in the code that the left-most menu is the File menu and it breaks if that's not the case. If you change the last line:
    to:
    hiInsertBannerMenu( window(1) trPulldownMenu 1 )
    then everything works fine. I'll file a CCR to get our code made more robust to tolerate the File not being the first pulldown menu.
  • sts
    sts over 2 years ago in reply to AurelBuche
    As you suggested loading menu with hiEnqueueCmd command at .cdsinit caused error to disappear.
  • sts
    sts over 2 years ago in reply to Andrew Beckett
    I inserted custom menu to position 1 without using hiEnqueueCmd command and it give no error at CIW as you said. However, I wonder if I insist to insert the custom menu to 0 position and use hiEnqueueCmd command so I see no error at CIW. Will it cause Virtuoso RF to misbehave or will it work totally?
    Sedat
    Andrew Beckett over 2 years ago in reply to sts
    Hi Sedat,
    If you use hiEnqueueCmd and leave it in position 0, then there would be no problem with Virtuoso RF. If you leave it at position 0 and don't enqueue it, then the File->Import menu would be missing the ability to import the Allegro database (that's what fails).
    I don't see a terribly good reason to add a custom menu in the left-most position though. It rather disturbs standard usage of the tools which is to have the File menu first. I have however filed a change request, CCR 2925943, to get this fixed. It shouldn't fail...
