  3. axlSetHistoryName deleting my history (bug ?)
  • Views 7473
AdrienL
AdrienL over 2 years ago
Hello!
I'm trying to rename my history/run after a simulation launched in skill.
So here is my code:
sim_run_name = maeRunSimulation(?session maestro_copy_session ?waitUntilDone t ?callback "atb_simulation_done")
history_ctx = axlGetHistoryEntry(mainSDB sim_run_name)
sprintf(new_history_name "atb_%s_%s_%ld" lib_name cell_name now_ts)
axlSetHistoryName(history_ctx new_history_name)
I run the simulation, wait it's finished, get the history handle and finally set a new history name. ( mainSDB is set before with axlGetMainSetupDB() )
If I run the commands one by one in the CIW it has the same result. Before axlSetHistoryName(), in my maestro/history folder I have the correct zip, and I can view the results with ADE.
But right after axlSetHistoryName(), it's renamed in ADE (nice), the zip file is renamed too (nice), but the zip file size changes to 0 (not nice) and I can't view the results in ADE.
I think it's a bug from Cadence (btw I use IC23.1-64b.ISR3.27).
Or maybe I didn't understand axlSetHistoryName() and use it the wrong way.
For the moment I see a workaround I might use, do a copy of the history and delete the previous one.
    Andrew Beckett over 2 years ago +1
    Yes, it looks to be a bug with the new history management. It's there in ISR4 too. There's an existing CCR 2599258 which I just added a prompt to that it should get fixed, but you might want to contact…
    Andrew Beckett over 2 years ago in reply to AdrienL +1
    AdrienL said: Do you have an idea of when it will be fixed ? No, sorry. It's not been committed yet. It's only been reported by one customer, so that may affect the prioritisation. Andrew
    Yes, it looks to be a bug with the new history management. It's there in ISR4 too. There's an existing CCR 2599258 which I just added a prompt to that it should get fixed, but you might want to contact customer support (submit a case after logging in) and ask for a duplicate to be filed on your behalf.
  • AdrienL
    AdrienL over 2 years ago in reply to Andrew Beckett
    Okay thanks a lot for your reply. Do you  have an idea of when it will be fixed ?
